heating up the heater?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BranndonC, Jun 3, 2002.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    How would i go about increasing the temp of the air coming from the heater? mine is warm now, but not really enough to heat you up on freezing cold nights. Any suggestions? also i kinda smell a sweet wierd smell sometimes, does that mean my heater core is bad? and how difficult is it to replace?
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    That sweet smell is anti freeze leaking and you might wanna change the thermostat to a hotter one for the winter months.
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i never see antifreez where i park... is it possible to just leak while driving? is the thermostat just something i can pick up at pepboys and install my self fairly easily? changing the tranny oil is about the extent of my mechanical skills.
  4. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Yes pepboys has the thermostat & yes you can change it yourself as for the leak look on the floor around the heater box on the passenger side or in the heater box or check the heater hoses that go to the firewall and Radiator check your whole cooling system out but find that leak. Espeacially if there are aniamls around cause anti-freeze in poisonous to them.
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Man, if you don't mind crawling under your truck and getting splashed by ATF, then doing the thermostat is going to be a breeze.
    Just drain your rad, undo the thermostat housing, and pull the old thermostat out. Now make sure that you clean the faces really well(scrape off all the old gasket material) and reinstall the new gasket and thermostat. Refill your rad and check for leaks.
    It's that simple. Don't be afraid to spend the extra couple of bucks on an upgraded thermostat.
  6. Mingler
    Mingler Registered Member
    Nov 2, 2001
    29
    Calgary, Alberta
    That sweet smell can only be one thing. Coolant.
    Double check your whole cooling system (follow the hoses) and if you don't find any leaks....there's a possibility you have a pin-hole leak in your heater core. (Not uncommon).
    As for the warm air issue. You could have air in your heater core from that possible hole. In some instances, your system will not circulate the full amount of coolant through the core because of this causing cooler air. Could also be due to your thermostat being stuck open. (Even a low temp thermostat should produce hot air.)
    Try poping off the rad cap (with a cold engine of course) run the engine till it's hot, have someone rev the engine at about 1200 RPM to get the coolant circulating. This can sometimes "Burp" the system to clear the air bubbles. If you notice your coolant level "really" drop during reving you may have got the culprit. Add more coolant while continueing to rev the engine.
    IMPORTANT - make sure you get the rad cap on before your buddy stops reving.......makes a real mess otherwise.!!!
    Onec you do that, You may notice that sweet smell a little more.....if this is the case....you found your leak as well....Heater Core!
    Hope that helps you out some.
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok, i'll change it out. two quick questions...
    1. is there a visible way to tell if it's bad?
    2. on the passenger side inside the truck near the kick panel on the floor, there's a oval shaped piece of plastic vent of some sort... what is that and how important is it that that is working properly?
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    corrosion causes the heater core to leak,
    I guess it could also block the coolant flow.
    I always drill a small hole (1/8 or so) in the thermostat to ease the removal of air from the system
  9. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    Others have given you the right advice about getting a higher temp thermostat. When I was living in FL, I ran a 160 degree unit as recommended by my computer chip manufacturer. Right before moving to the Northeast, I switched to a 180 degree therm, but even that wasn't enough for really terrific heat. Finally, I tried 192 degrees and THAT did the trick. Feels great after a long day of skiing! Initially, I thought the 192 might cause the truck to run a little warm in the summer months, but that is not the case at all, so I leave it in there year round.
  10. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks for all the help guys. I'll look into one soon.
  11. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    With a TBI I would run a 195° thermostat. Also make sure you have the heat riser tube installed. I ran the heater hose on mine back to the water pump (instead of the rad) and capped off the radiator nipple, seemed to help also.
    Pete
  12. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    Now how does this work again?? I ran mine on another truck from the core to the intake and one to the water pump and NOTHING,..... wouldn't circulate.....how did you do this with yours and get it to work......maybe I missed something..........I would suggest for the main question to change the core it's really not to difficult and you'll be glad you did, the high thermostat is a must. Dont mean to spoog your post but I did the other suggestion and it just overheated the motor.....wouldn't want you to go through this. good luck
  13. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    I removed a plug from my water pump and ran the hose that used to go to the radiator to it (after threading in a nipple). A lot of passenger cars are like this, I think by Brother's '70 K5 may be this way too (or it could have been my other brother's '88 TA I was looking at). It seemed to help; I was daily driving mine for a few months during the winter a couple years ago, and with the fenders all hacked out and no inner fender wells, was having a hard time keeping any heat in the motor. I also advanced the timing like 8°, which helped.
    Pete
  14. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    well i was just talking to my gilrfriends dad and he said changing the thermostat to a higher one would do absoltely nothing as far as increasing the temp of the air coming from the heater, it would just make it heat up faster, is this true?
  15. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    No, it's not true. The engine coolant will get hotter if there's a higher rated thermostat installed. This means that hotter coolant will be flowing through the heater core, so it can pump more BTU's into the cab. /forums/images/icons/cool.gif
    Think about it this way: Does it produce much heat when you first start it on a cold morning? There's coolant flowing through the heater core. /forums/images/icons/wink.gif The hotter the coolant gets, the more heat that you feel coming out of the vents. /forums/images/icons/shocked.gif
  16. dyeager535
    26,977
    Bought my car and noticed heater didn't really get warm. Found out no thermostat. Afterwards, plenty of heat. Not true that it doesn't matter.
  17. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    That is wrong. A thermostat works by restricting the flow of water through the engine. If the thermostat is stuck wide open then the free flow of coolant would prevent the engine from retaining the heat that it does need. When my thermostat went bad on My wife's dodge caravan, you could run it up a canyon, open the radiator cap and touch the lukewarm coolant in the radiator. This was the same temp. water going through heater core and needless to say, the interior of car wouldn't heat up. Running too cool also prevents the computerized fuel injection from working properly too, (so I've been told) Also, when your heater just all the sudden goes cold, you've likely lost alot of coolant and ya better pull over and shut it down (amusing sister in law story) or your gonna sieze it up.
  18. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    well right now my truck never gets hot, think my thermostat might be bad?
  19. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    replace it , its not hard at all /forums/images/icons/smile.gif
  20. daniel.wilson
    daniel.wilson Newbie
    Apr 16, 2002
    3
    If you're going to change the core check out Eric's article on this website. I followed it last week and it was pretty straightforward. You probably wouldn't see any antifreeze outside the vehicle because GM was kind enough to install a system to absorb all of that coolant leaking from the heater core - they call it carpet padding. Seriously, pull the carpet back and see if your padding is soaked. Also, compress the insulation on the firewall right below the heater box. When mine went, that insulation was just saturated with coolant as was the carpet pad most of the way to the passenger seat.
