Heavy Duty 3/4 ton front axle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Sep 26, 2001.
Thread Status:
Not open for further replies.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    What would this be considered? He says it's stronger than most 3/4 ton front axles and it's closer in strength to a Dana 60. I already have a lead on a nice 10 bolt but was wondering what a Heavy Duty front 3/4 ton axle consisted of. Oh yea... he said they usually charge between 450-500.
    89 K5 Silverado
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Could be a Dana 50.
    Found in Fords.
    Poundin' the ol "pavment"!
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Sorry, I'm lost...Who said this? Is this someone selling you an axle? AFAIK, its gonna be a 10 bolt, Dana 44 and then there really isn't anything else till you get to the Dana 60. Ford has a Dana 50 in their Super Duty trucks...but it would need some serious mods to work in a K5.
    Rene
  4. not4show
    not4show 1/2 ton status
    Apr 24, 2001
    280
    Alabama
    Yep, that's exactly what I was thinking too.
    Never put a stupid move passed a stupid person.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I agree with the others. I think this guy is blowing smoke up your a**. It's might be a beefed up 10 bolt or 44. It was printed somewhere that if you use the chromo axles in a 10 bolt or D44 that you were approaching stock D60 strength, but if that were the case and it had these axle shaft it's not going to be $500. Those parts alone are more then $500.
  6. RedDwarf
    May 9, 2001
    816
    You can't believe everthing you read. 1/2 ton stuff can never be what a Dana 60 is. Tubes, housing, bearings, gearset, none of those even come close to a 60.
    There just really isn't a substitute....
  7. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    careful Red you will shatter their illusions
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I know. I didn't clearify well enough. What I read, and meant to say was the chromo axle shafts for a 10 bolt were approaching stock D60 axle shaft strength. That just what I read though. I know that the bearings, u-joints, etc. wouldn't be as strong.
  9. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Quit knocking the 10b's.... just because you dislike them doesn't mean they suck... if they are such crap why does the owner of Offroad Design use them????? How come he won second in the TTC with such crap axles?????
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    Suck Fumes Ford Boy
    &lt;&gt;&lt; PSALMS 23 &gt;&lt;&gt;
  10. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    uh actually he didnt use them in ttc , he upgraded to a dana 60 and a 14 bolt ff , before hand , and i have his old "crap axles" :) yay !
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    STEPHENS OLD AXLES
    NO BREAKAGE :)
  11. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    My mistake in the way I worded that... I didn't mean he used them for it... I was meaning he obviously knows what he is saying when he says they can hold up to stuff since he won 2nd in TTC... if he says they are decent axles then they are because he sort of is in the business of knowing his stuff...
    Suck Fumes Ford Boy
  12. iceman
    iceman 1/2 ton status
    Oct 26, 2000
    208
    Littleton, CO. 80127
    I came across the HD designation in reference to the 3/4 ton large hub design used in the mid 70's, I don't know why they did it, but it's the only mention of HD I could find. I suppose because of the spindle and hub being heavier than the 1/2 ton version it got the HD attached to it. Go figure? Iceman
  13. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    I had a front and rear from a 76 k20 "HD". Powermad has the front end now :) Maybe he has more insight on this one?
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  14. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Ford did it in the 70's too - I had a 77.5 F250 with the D44 HD - bigger spindles and hubs were the only difference.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  15. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    After a bit of research I came to the conclusion that the only reason the 3/4 ton mid 70's D44 was classed as a HD was the big ol external hub.
    The axle shafts are the same as a 1/2 ton and untill 76 the tube OD is 2 3/4". In 77 they did away with the external hubs and the tubes went to 3" on 1/2 and 3/4 tons.
    If what he is refering to is an external hub D44 then $450-$500 is way to much unless it has chromo shafts in it.
    As soon as I get new wheels I plan on fiding out just how heavy duty it is.
    But since I have not managed to break the 6 lug one that I have now I forsee no problems.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  16. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Wow.. I go to bed and wake up and I have a lot of replies [​IMG]. Gotta love this site.
    Ok.. heres the whole scoope. I received an email from a guy that saw my rig profile on rockcrawler.com. He said he was in the same town as me and him and some friends were looking for some four wheeling buddies. So naturally I told him I was up for it. So we start talking about our rigs, and I tell him I am in the middle of a 3/4 ton coversion and I wouldn't be able to wheel till I bought a chevy 3/4 ton front axle with 4.10's. So he replied back about a few other things and he said he had leads on a bunch of them. I know you can't beleive everything you hear but he builds drag cars for a living so I figure he has to know something?!? Anyway he emails me back and says he has this axle but wants to know how much I was willing to pay. I told him I'm already talking to someone else about a front 10 bolt (which we haven't set an exact price but $250 was mentioned). The 10 bolt is ready to go in and even comes with a few extra parts. So this dude with the "HD" writes back about his this is the email I received:
    "that is a slammin deal is it in good running condition the one i got needs nothing and is the real heavy duty unit not just the regular 3/4 ton but more like a one ton"
    The really slamming deal he is referring to is the 10 bolt for $250. Now I'm aware they basically jump from a D44 to D60 for chevy applications, but we all learn something new everyday and I thought maybe someone can shed some insight on the situation. Anyway.. the guy said if I want it I can have it for $380. Which is still a lot!! I emailed him back asking about if it was still a 8.5" Ring and Pinion, 28 or 30 spline and so on. I haven't received word yet but I'll call him tonight and get the whole scoop.
    89 K5 Silverado
  17. Grim-Reaper
    7,385
    Atlanta
    The "HD 3/4 ton" is a D44 with half inch thick walled axle tubes. SO it's more resistant to bending. However most 10's and D44's don't fail as a result of the tube bending theyfail when the casting at the pumpkin where the tube is pressed breaks.
    The external hub D44 is no stronger than the internal and a PIA to find Hubs for. The shafts are the same and if it's a pre 74 they may even be weaker. Any D44 or 10 bolt after 74 is what you want. Just find one with 8 lugs and go with it.
    I don't need no damn shop manual, I got a pornographic memory.
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  18. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Hmm... ok.. .that answers my question then. No need in paying $400 for an old out of date axle when I can get a decent one for around $250.
    89 K5 Silverado
  19. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Actually, I thought the external was gonna be a bitch to find hubs for too, but it wasn't all that hard. Warn and Superwinch both make hubs. I'm running an external style on the front of mine. No complaints to speak of.
    Other than that, yep, I agree.
    Kyle
    89K5
  20. RedDwarf
    May 9, 2001
    816
    Whoa, take it easy ChevyCaGal!
    Noone is calling the 10 bolt a "crap" axle. It's a great 1/2 ton unit that some people underrate. But they are a light-duty axle. They won't stand up to bash and crash or lots of torque. If you wheel easy, then they might survive. Then again, they might not. Sometimes stuff breaks even if you are not dogging it.
    I own 4 10 bolts and I know them pretty well.
    Stephen Watson knows them pretty well too, that's why when he got ready to go to TTC, he upgraded to a 14 bolt and Dana 60.
    If a 10 bolt is all you can afford right now, then that's what you've got to work with. I am in the same boat, so my rig is running a Dana 44 in front right now. When I get a chance, I will go up to the 60.
Thread Status:
