heavy duty 350 M block engine, crankshaft ?
Discussion in 'The Garage' started by R72K5, Nov 27, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i know where an old 69-79 2bbl heavy duty M block 350 truck engine is at, or at least hopefully is stil there, 50 or 60 series truck engine,
    i would think the crank in these would be forged or steel
    and i wonder what pistons were used in these
    i already got the bellhousing adapter plate and some other things from it including the 4 groove crank pulley, etc.
    the bellhousing plate is a stamped steel plate that allows use of the massive CH465 bellhousing, it is huge, way bigger than any 1 ton and smaller bellhousing, the flywheel has to be at least 16" across if not more
    i wonder about that bottom end,
    hmm
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Check the parting line on the crank.
  3. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    The cranks in any c50 is a forged steel crank with ultra low compression. I have found this out by working a few the last two weekends. The pistons are dish(like looking into a bucket dished)but they are thick and normally use 4 rings instead of the standard 3 rings. Hope this helped out some.
    bigred81
