Heavy Duty clutches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GUMBY, Jun 16, 2001.
  1. GUMBY
    GUMBY Registered Member
    May 17, 2000
    35
    Alabama
    I am replacing my clutch soon and would like to go with a heavy duty one. I would like to know if someone is familiar with Centerforce. I've been told that the more heavier duty you go, the harder the clutch becomes to push and keep pushed down. Who has used a Centerforce Stage II or double disk and what are your opinions on these or any heavy duty clutch?
  2. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    I have a Centerforce II and have not one bad thing to say about them. I like to do the slow stuff like rocks and the clutch is easy on the foot and it'll last for a while, price isnt that bad either.
    <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A>
  3. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    I dont run a centerforce but the clutch I have is a dual friction type, similar to the centerforce, just made by a local clutch company. Deffinatley worth it, especially behind my Big Block!! Pedal force is no more than what the stock clutch was before.
    78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt w/ Detroit
    <A target="_blank" HREF=http://www.bowtiecrawler.com>http://www.bowtiecrawler.com</A>
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have heard centerforce and Ram are the best 2 out there. Everything else is just a copy of theirs.
    '71 Blazer CST with alot of rust
  5. K10
    K10 Registered Member
    Feb 18, 2001
    52
    Rexburg, Idaho
    I have a centerforce dual friction and it works great.
    <A target="_blank" HREF=http://nick.rockcrawler.com>http://nick.rockcrawler.com</A>
  6. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    Ok... this is probably stupid but Automatics have clutches also right? If so is the an Automatic clutch the same as a Standard? Can a Centerforce be used in an Automatic? Thanx
    Chad
  7. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    The only stupid question is the one that isn't asked.
    An automatic uses a torque convertor in place of a clutch and pressure plate. The torque convertor allows enough slippage for the motor to continue running in gear and stopped.
    The clutches in an automatic are a completely different animal and are used to apply and release the different parts of the planetary mechanisms inside the auto. This is how the different gears are acheived.
    So in short a 'centerforce' type clutch cannot be used with an auto.
    Rene
  8. ChadH82
    May 9, 2001
    400
    Ya, my cousin just told me it was the torque converter I was looking at. Thanks for the info!
    Chad
  9. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I have run Centerforce before in some hi perf cars and they are excellent.
    Chad BTW... if you were looking for good clutches for an automatic I strongly recomend the Reybestos Blues for anything such as a daily driver or street setup. I have them in my freshly rebuilt 700 ( and have used them for quite a while in numerous vehicles) and they are great.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i think you are thinking of the clutch packs in the trans, but in a way yes they have a clutch, several of them in fack. but they have a converter (as stated above) where the clutch is on a manual trans. at low RPM the convertov multiplies tourque by about 3 times. ( this is on average).
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  11. ChadH82
    May 9, 2001
    400
    Ok, thanx for the info.
    Chad
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    Centerforce clutches are designed to grab hard without the hard pedal presures. That is with they use centrifigual force...
    I would reccomend either centerforce or Hayes
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  13. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I use the Centerforce Dual Friction. I have a manual linkage on my 83. The pedal pressure increased every so slightly. I dont notice it anymore. It works great.
    My .02
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '83 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allison Auto
