Heavy Duty Drive Shafts??
Discussion in 'The Garage' started by pitbulls'n'blazers, Jan 20, 2006.
  1. pitbulls'n'blazers
    pitbulls'n'blazers Registered Member
    Jan 18, 2006
    67
    Missouri
    What drive shaft do you guys think is best and what size? The one's on my K5 look kinda small,and I'm worried that I will be on the trail doing a bit of crawlin' or boggin' and the drive shaft will break or twist.
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    really want to recommend the search feature to you - it will yield TONS of results on this topic as well as the other threads you've posted up. that being said, i don't know anything about driveshaft tech, so i can't help much. however, i do know this topic has been covered alot.
  3. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    if its a trail only machine, save your money and consider square shafts... I don't have any pics of mine before install, but...
    click for full-size...
    maybe you can see them... or maybe I just like to pic whore;)
    more info and pics...
    -micah
  4. pitbulls'n'blazers
    Jan 18, 2006
    67
    Missouri
    Thanks guys for the feed back,and good idea about the square drive shafts,but my truck is not just a trail machine.Tough lookin' Blazer ya got there.I am going to use that search more so I won't put up the same thing over and over again.:doah:
    Thanks again guys!
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I would venture to say your stock shafts will be just fine. I have been Rock crawling on mine for 2 years now and haven't even busted a u joint in them.
    I do however carry spares for the front and rear. At the cost of High end drivelines, I have no problems running my stock ones and feeling good about it.
  6. pitbulls'n'blazers
    Jan 18, 2006
    67
    Missouri
    Hmmm? If your stock one's where good enough for rock crawlin' there good enough for me.:D
