Heavy Duty FLOOR REAPAIRS and rocker repair rock sliders, TONS of pics
Discussion in 'The Body Shop' started by jjlaughner, Apr 15, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Last update I'll start a new post for whatever happens next /forums/images/graemlins/histerical.gif
    TON OF PICS HERE - If they dont load, right click "show picture"
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    OK I'll contribute something that might be of worth
    I think this fender bolt is the hardest thing to work around when doing silders
    I'm using 3x3 1/8th wall square tube and I ended up having t notch out about 3/8" to get it to fit around the bolt. What I ended up doing is welding in a plate to the ends (I notched out a 3/8" gap and an extra 3/8" for the plate to go back in)
    I'm going to drill two more holes (one on either side of the fender bolt a couple pics up), hold the slider up tight and mark those two holes on the 3/8" plate I welded in to the ends of the slider. Then drill the holes and bolt it to the fender flange. When the slider is mounted there will be two bolt there so in the future if I pull the fender I can still unbolt it and not have to cut it off from welding it (plus I can't weld upsidedown and backward in the wheel well so this is my work around /forums/images/graemlins/ignore.gif)
    EVEN MORE PICS /forums/images/graemlins/whistling.gif
    Ended up knotching the sliders cut a hole for the fender bolt to go into and then stuck two bolts in the front fender/mount, welded the rear and I'm planning on a pan head bolt to bolt it to the crossmember. I still need to brace the silder back to the floor support and lay the front floors in /forums/images/graemlins/tongue.gif
    Drivers side is done, I'm going to trim tomorrow
    This is how I regapped the door /forums/images/graemlins/histerical.gif
    what does a perfectly RE-gapped door sound like? Click here (quicktime)
    not bad for a an old loose rusted out POS that the doors didn't even close a couple days ago! floors are gone and all the loose stuff has been trimmed or tack welded /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
    More pics after this weekend when the front floors go in /forums/images/graemlins/waytogo.gif
    rear floor repairs
    Future plans
    tons of pics from when I brought it home
  2. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    Re: My sliders, TONS of pics
    i'd swear i was looking at my truck, when i look at your non existant floors. i'm in the same boat as you right now, i just got all of the rotted and loose crap cut off. getting ready for the new floors, but you've got to admit the whole Flintstones thing is kinda cool /forums/images/graemlins/waytogo.gif good luck with everything
    Nate /forums/images/graemlins/k5.gif
  3. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Looks just like my K5, only you seem to have a rear floor in yours where I'm just cutting mine out. It's really nice that you post all these pictures since you're a step ahead of me and it's nice to know what I'm getting myself into. Keep up the good work /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/peace.gif
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/waytogo.gif thats what I done watching others /forums/images/graemlins/deal.gif
    Bad Dog has been a huge help to me /forums/images/graemlins/waytogo.gif
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Make sure you post up how they work off-road /forums/images/graemlins/laugh.gif
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/waytogo.gif if all goes well maybe the 24th of next month :fingerscrossed:
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Man you really weren't kiddin about the pics! /forums/images/graemlins/rotfl.gif Don't worry they are good pics and its interesting to see that at least one of us is gettin some work done!
  8. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Very creative. I guess I'm going the easy route by swapping in some stock springs... although they are from a '95 2wd chevy /forums/images/graemlins/waytogo.gif
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    what size are the springs on a 95? /forums/images/graemlins/ears.gif
  10. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    more pics
    [​IMG] cross braces
    [​IMG] Jack test
    [​IMG] /forums/images/graemlins/waytogo.gif
    [​IMG] update on the fender trimming
    [​IMG] Put my racing bucket in to test it out /forums/images/graemlins/waytogo.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  11. blazenj
    blazenj Registered Member
    Jul 20, 2003
    27
    High Desert,So.CA.
    Have you got those welded to the frame and the body?
    the reason i ask is the body moves independent of the frame doesn't it? /forums/images/graemlins/thinking.gif
  12. lifethroughdeath
    Jan 26, 2003
    300
    New Bedford, MA
    i think he's got them attached to the sub frame which is attached to the body
  13. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    There is a body support the runs under the truck next to the frame.. the braces are welded to the that. The supports and sliders are welded to the body mounts, once the floors are done (WOO HOO they are thay are cut and in, just need bolted and welded), once the floors are done the body mount bolts will tie everything together /forums/images/graemlins/waytogo.gif
    you can see in this pic the sub frame/body support and the frame are to different items right next to each other
    so no the slider supports are not welded to teh frame, the body will still flex at the mounts. The body support, the cross mounts and the slider is welded together, there will be a piece of angle tieing the slider and the floors together, the floors will be bolted and welded to the subframe and the main body mounts will be welded and bolted to the floors /forums/images/graemlins/grin.gif Right now the slider clearence (with no lift) is about 18-19", I had a 21" jack and 10 section of wood jacking the truck up by the sliders and flexed on the body mounts. Once the floors are bolted and welded it will be a SOLID truck again.
  14. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    so what are you using for the front floor? 1/8" diamond plate?
    i need to hire you to mine /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
    that thing has come a long way /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  15. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Let me go get my camera and I'll post some pics.... YES 1/8" diamond tread front floors also /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
    (they look freakin cool by the way /forums/images/graemlins/wink.gif )
    You make my cage and I'll start your floors /forums/images/graemlins/histerical.gif
    guess what my belly pan and front skid plate will be made of /forums/images/graemlins/whistling.gif
  16. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    [​IMG] outline of drivers side
    [​IMG] both sides cut and bent, getting rust proofing paint /forums/images/graemlins/waytogo.gif
    BEFORE [​IMG]
    After [​IMG]
    [​IMG] Seam in the middle
    it was easier to go in, in two pieces
    [​IMG] the center hump will get beat down and welded
    dimentions we used on this truck... I dont know if this will work for all trucks /forums/images/graemlins/dunno.gif
    <font color="red"> Almost done!!!!!!!!!!!!!!!!!! </font>
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    WOW that looks really good, do you get that stuff for cheap, or how come you use so much /forums/images/graemlins/whistling.gif
  18. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    so far I have bought three sheets (I still have more than half a sheet left in leftovers). I think I have something like 3 - 4'x8' sheets of 1/8" diamond plate, 8' of 4x1/4" plate, somewhere in the neighborhood of 20' of 1-1/2" 3/16" angle, 7' -2x3" 1/8th wall tube, 10' of 3x3 1/8th wall tube, and several little things here and there. I have about $400 in steel so far... probley 400 hours in the floors too /forums/images/graemlins/whistling.gif
    WHY? I like diamond tread /forums/images/graemlins/peace.gif the local places can't get anything thinner than 1/8th... plus since the floors going back do not have ribbing and they are basically supporting the weight of the body at th edges it needs to be thicker than stock /forums/images/graemlins/deal.gif /forums/images/graemlins/waytogo.gif
    /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif the floors are almost done /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif the floors are almost done /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif the floors are almost done /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif the floors are almost done /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif the floors are almost done /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif the floors are almost done /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif the floors are almost done /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif the floors are almost done /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif the floors are almost done /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif the floors are almost done /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  19. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    DUDE! The floor looks totally awesome. /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
    It is going to be strong as Sherman tank. /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  20. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    padder
    pad
