heavy duty radiator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lasvegas, Oct 21, 2001.
  1. lasvegas
    lasvegas 1/2 ton status
    Feb 27, 2001
    122
    Las Vegas, Nevada
    I am finishing up installation of my ZZ4 crate motor into a '78 blazer. I bought a 4 row radiator from Raditor.com and I know I need bigger rubber pieces, the four that cradle the raditor in its supports. Anyone know the correct part number for those cradles. Also, does anyone know if I need a different top part (I don't know what it is called) that bolts against the front support that holds the radiator down? If so, anyone know the part number. Thanks!!!!
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You need a new top part. I just did this in my burb. Sorry no part numbes though. Just call the parts dep. t chevy and tell them you new the rubbers and the top part for a 78 454 suburban. They get it right that way.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    PM Big Burb, I think he was the one that had the rubber bumpers part numbers as well as the top part.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  4. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    You can get those rubber parts through Classic Industries. I swapped in a big block radiator into my small block Chevelle a while back and was able to use the same top support. I even used the same rubber bumpers. Kind of crude, but they worked.
    <font color=red>"SETTING OFF ALARMS IN A CITY NEAR YOU!"</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
  5. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Gm part #'s are as follows..... upper metal bracket p#14018600 , rubber pads p#6264100 , shroud p#14021289 , and that should do ya' CC
    1991 Fullsize 5 1/2"lift, 37"ssr's,10Bolt8 lug , 14Bolt ff, 4:56 Detroit rear, 12"fr. 14"r Bilstein remote res.350 P.F.I , 700r4 , 241c W/ sye
