Heavy Duty U-bolt Source?
Discussion in 'The Garage' started by nvrenuf, Aug 20, 2006.
  1. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Any suggestions for a place to get GOOD / HIGH QUALITY heavy duty u-bolts? I want 3/4" dia, 8 grade stuff (or better) bent to my specs.
    I had a new "grade 8" set that I just tried to install but 2 of them stripped out. :mad: I put them on with a 1/2 ratchet (not air gun) and realized I needed to take them off to change something and the damn things were galled(?) in the nuts. :mad: :mad: These things might have been tightened to 75ftlbs.. I'm going to contact the guy I bought them from but I just don't know if I trust his source now. :crazy: :doah:
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    5/8 and up in rod is grd8 for ubolts.
    my local spring shop uses l&h rod company and thay work great.
    best try the good truck/spring shops.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Wow! 3/4" is pretty thick for u-bolts on light duty trucks. I don't see how you can have any problems with that thick of bolts on our size of trucks.
    I get all mine from either ITP or small hole-in-the-wall business in Salina, a town 40 miles east of me. Both have competitive prices and pretty much the same material. I use one or the other depending on if its a weekend or not.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    BTW, I forgot to mention that Superlift makes good, high quality u-bolts. I know all theirs are grade 8's but they only show 1/2", 9/16" and 5/8" bolts.
  5. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    you can order them from deaver spring in Santa ana california if you want something special but the super lift ones are good quality and come in most sizes.
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    That's exactly why I was so pissed when they stripped. I know 3/4" is big but with the 4" axle tubes "normal" size u-bolts looks kinda cheesy. :doah: :rotfl:
    I may call Deaver and see how much they want. :thumb:
  7. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    I had the same problem with my 1st set of ubolts. they got a burr from the washer mashing down at the threads and it would not come off. I had to cut it and get some fresh ones. I chased the threads on the others to clean them after I pulled them off.
  8. Musclerodz
    Musclerodz 1/2 ton status
    Apr 23, 2005
    121
    Washington, OK
    Sounds like a cut thread instead of a rolled thread. Even so, I would not think it would have stripped if it was actually grade 8.
    Mike
  9. sweetk30
    Nov 1, 2004
    25,526
    526
    stock is 9/16 rod on most. comon upgrade is 5/8 rod. fits in the plate holes and is much stronger. 3/4 is over kill to the max on a 1 ton truck. those things are on 2 ton and up.
  10. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    :D Thank you :D
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    :haha: :haha: :haha: :haha: :haha:
    No such thing as "overkill" for you, eh?
  12. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Nope ;)
    I'll agree it sounds like overkill but when you actually see them installed they look perfectly natural.
