"Heavy" half ton...
Discussion in 'The Garage' started by Avery4jc, Aug 31, 2006.
  1. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
  2. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    What do you mean they are 3/4 ton and have 1 ton stuff? If you mean a 14b in a 3/4 ton its not a 1 ton 14b. Has a smaller ring gear and its a semil float instead of full float axle.
    If that wasn't what you were talking about then I have no idea.
  3. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    No that was along the lines of what I was talking about. I know some of them were 14sf/d44 setups instead of a 14ff/d60 like a one ton but basically I just wanted to know what a "heavy" half ton was.
    -Avery
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    A heavy half was the half ton truck with a SF 14bolt. They were 3/4ton light duty if you will. And as far as 3/4 ton 14 bolts not the same as 1 ton that is just incorrect. The 14FF was offered in a 3/4 ton and to my knowledge was a more available option than the 14SF.
    Ira
  5. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Ok cool.
    -Avery
  6. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I know nothing about "heavy" half tons but it just so happens a guy mentioned those trucks to me just the other day. He said they had a 12 bolt?????? I have no idea if that's correct. I am still learning all this stuff and I've heard people talk 10 bolts and 14 bolts but never a 12.
  7. sandawgk5
    Oct 28, 2003
    6,881
    Only 12 bolts I have seen are in the older half ton pickups and blazers but never heard then refered to as a heavy half. I always though 12 bolts were before they had a 10 bolt rear:dunno: . I have always heard of heavy half as a pickup with a 14SF. I cannot see what lug this truck is but they did have 6 lug 14SF.
    Ira
  8. beastofablaze
    Apr 4, 2005
    441
    CA
    you sure? Because When I asked that question a LONG time ago it was explained to me as 14sf 3/4 14ff 1 ton never heard of a 14ff 3/4 ton.
  9. sandawgk5
    Oct 28, 2003
    6,881
    Yep I had one that I drove to highschool and I have one in my K5 right now.:D
    Ira
  10. beastofablaze
    Apr 4, 2005
    441
    CA
    so the ring gear is the same and everything huh?
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    All the heavy halfs I have seen were 5 lug 2wd or 6 lug 4wd this is of course prior to the new stuff in the late 80's 90's and currently .
    I am talking about the real trucks prior to losing the SFA :thumb:
  12. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Heavy halfs were designed to "outsmart the government". Something to do with gvwr and emissions.
  13. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    All the 70's 3/4 tons had 14bff's to my knowledge. I didn't think the 14sf came along until the early 80's. I have seen plenty of 14bff's that were 3/4 ton, those are the ones that swap easily into your half ton, cause they had the same perch width as a 1/2 ton. The 1-ton 14bff's have a different perch width, and have to be cut off and relocated in order to work on a 1/2 ton. So there's definitely a TON of 3/4 ton 14bff's out there.
  14. sandawgk5
    Oct 28, 2003
    6,881
    Yep I have a 3/4 ton 10.5" ring gear 14FF with a 2 piece carrier with a drop in Detroit No spin. A 14FF is 10.5 and a 14SF is a 9.5:D . All 14FF are the same except for spring pad width and shock location. Well that and the newer ones have a slide on drums.
    Ira
  15. sandawgk5
    Oct 28, 2003
    6,881
    Think of it more like the 1500HD that is available today:D
    Ira
  16. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    What I was always told was
    Half tons have 305s
    Heavy Halfs have 350s
    The 14SF was after the body style changed in 88 and the 14sf and 14ff were jocketed between 2500s not 1500s as far as I know
  17. sandawgk5
    Oct 28, 2003
    6,881
    The 14SF came out in like 79 as I have seen some old CKs with 14SFs in them. In reality it is not worth getting Avery over J/K:D .
    Ira
  18. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Heavy-halfs were a badged package labeled a 1500 but basically 3/4ton springs and axle
    basically 1/2 ton tow package probably a 350
  19. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    No kiddin, huh Ive never seen one in anything older then an 88, good to know though.
    We cant forget the Quad Shock Package. That from what Ive heard have come on some trucks with plow package, without, 6.2s too.
  20. sandawgk5
    Oct 28, 2003
    6,881
    Ya I had that on my 87 silverado 350 K5 but it gots some 12" travel gabriels with ford towers now:D . Chevy did some strange things over the years.
    Ira
