Heavy smoke at startup....
Discussion in '1982-Present GM Diesel' started by Can Can, Jan 24, 2002.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I know that diesels generally smoke more when cold, but lately my 6.2 smokes WAY too much out of the passenger side exhaust when I start it up. The smoke stays pretty thick for a couple of minutes, then slowly disappears. I don't have a connector pipe joining the two exhaust pipes, so I can be pretty sure that the problem lies on the passenger side of the motor.
    I know that a plugged injector can cause smoke, but I was under the impression that a clogged injector will ALWAYS cause an overly-smoky exhaust. Do these symptoms sound like they are injector related? If so, is it best to change ALL the injectors out at the same time?
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
  2. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    My driver's side exhaust did this when it got cold, until I changed out my glowplugs. I just had one or two cylinders that weren't quite firing until the truck ran for about 20-30 seconds.
    What color is the smoke?
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  3. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Can it be that some injection nozzles drip?
    Perhaps it becomes better, if you adjust the pressure
    (1900psi), or you overhaul the nozzles.
