Heavy vibration and rattle after 4" lift...need help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chev4life, Aug 15, 2002.
  1. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    Heavy vibration and rattle after 4\" lift...need help
    I recently lifted my '87 K5 4" using Superlift springs all around and all the new goodies to make it work. It rides great, tows better and I am way pumped....but there is one problem....when I let off the gas at any speed over 15-20 mph I get a rattling/vibration type thing happening in the entire truck. It sounds like it is metal to metal and I can deff feel it under my feet. Has any one else experienced this?....or know what is going on. I still have stock exhaust to the cat....and already checked the new exhaust after with no problems found. Thanks. /forums/images/icons/confused.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: Heavy vibration and rattle after 4\" lift...need help
    I would guess u-joints would be the first thing to check. They can be OK with out a lift but the extra angle might have done an older one in when it was lifted up.
  3. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Did you lower the tcase at all? Check your rear driveline angle...most 4" kits don't create a problem, but on occasion the lift makes the rear driveline angle too severe, and the slip yoke will hit the fixed yoke on the driveshaft. Chock the wheels, throw it in neutral and crawl underneath and rotate the shaft. You'll be able to see if the driveshaft is hanging up on itself.
  4. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    I will check all the joints...if needed, how difficult is it to replace the u-joints and lower the t-case. I thought about doing the t-case but never got that far.
  5. Scott73
    Scott73 Registered Member
    May 22, 2002
    38
    Electra, TX
    lowering the transfer case is pretty simple. Support the transmission and transfer case, remove the 4 bolts from the crossmember and relocate the spacers that are under the crossmember to between the crossmember and the frame. Takes 10 to 20 minutes. I just did my '87 this weekend.
  6. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Yup, that's how I have done it.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    Of course, you have to lift the rear wheels off the ground to check the rear driveshaft, or at minimum one of them.
  8. Oddball
    Oddball Registered Member
    Dec 28, 2000
    46
    Norway
    Drop the T-case and check / lubricate the joints...
    If you got grinding noise i would have them changed.
    I lifted my 77 4 "-- and didnt drop the t-case at first..
    so front shaft broke.. then i dropped the t-case.. no moore vib's.. but then rear shaft joint said godbye on the highway going 75. that wasnt fun
    Truck is ok now.
