hedder gaskets??????
Discussion in 'The Garage' started by mean77, Apr 24, 2002.
  1. mean77
    mean77 Registered Member
    Mar 5, 2002
    6
    I was wanting some opinions on hedder gaskets. What gasket will give me the best seal? Are the copper, aluminum, or fiber gaskets better? Any help is greatly appreciated.
    Eatin jeeps, its an ego thing!
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    it all depends on your maintanance on the header bolts. i have had a set of the Mr Gasket aluminum core/felt gaskets for over a year and no problems, as long as the bolts are tightened, you should have no problems.
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Regular exhaust manifold gaskets have always worked good for me on my hedders.
  4. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    I have heard (never tried), that if you take regular headder gaskets and soak them in water and then install them they make a great seal....
  5. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I've heard that one too. Also, go back and tighten your bolts again after your first run with them on.
  6. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i have run felpro gaskets and they have been okay but recently i switched to the aluminum gasket and i love them. if your headers aren't perfect (mounting surface) theses are the ticket.
  7. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    If they are anything like collector gaskets get aluminum ones. I kept blowing collector gaskets like once a month switched to aluminum ones and haven't had a problem in 4months now. I plan on switching to aluminum header gaskets this summer as I am developing a leak with my current ones.
  8. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Where can you get the aluminum gaskets, don't think I have seen them before?
  9. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
  10. BowtieBlazer
    Jul 15, 2001
    2,462
    Just about every parts store carries them. You may have to ask.
  11. beater74
    May 29, 2001
    1,749
    atlanta
  12. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I have those funny aluminum coated ones. However, I was told, (I didn't believe it) to use Bronze Copper silicone gasket maker stuff. This is the most expensive silicone gasket on the shelf. It's supposed be good to 750 degrees.
    Anyways, I put it on my headers (aluminum) and my collectors (cardboard looking ones). Has not leaked since.
    NOTE: Maker sure you get the O2 sensor safe kind! Especially if you have an O2 sensor like me!
    This has been on my truck for 2 years now. No problems!
    BTW: I have poly engine mounts and hard mounted (no rubber) the exhaust mufflers to the frame.
  13. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    TopOff, Ya' stole' my thunder! I was reading this post and getting ready to spring that one on'em but ya' beat me to it. My buddy wrenches on race cars, roundy-rounders and drags, and he said even NASCAR uses the stuff and that made it good enough for me! Hasn't leaked yet! I also cut and contoured my header flanges.
  14. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Bust out the sawsall and cut the flanges between the inner and outer tubes and they will seal better.
  15. twojoints444
    twojoints444 Registered Member
    Sep 14, 2009
    95
    B.C. Canada
    any one elts do this? did it help
  16. bailey9r
    bailey9r 1/2 ton status
    Feb 6, 2008
    300
    High Springs Fl
    Yes and some of the better header companies do it like that from the factory, they can "mold" to the head better.
  17. scottsdale86
    scottsdale86 1/2 ton status
    Oct 19, 2010
    1,123
    San Bernardino ca
    Go back to manifolds. EVERY single pair of headers i have ever had on a my 86 has leaked. I have tried the edelbrock, headman etc. Went back to stock not one leak. Headers unless the full length kind dont make any real noticeable power gains. at least on my truck it didnt. I have 290hp gm crate engine with a stock intake and new quadrajet and 700r4 with 4.10 gearing on 35's, Biggest bang for my buck was the carb. I have tried percy's xtra thick aluminum, Mr. G's grey, copper thick ones and white paper gaskets. Nothing worked.
  18. ryoken
    Jun 13, 2003
    29,623
    1,376
    Jersey Shore
    i've run Hooker comps quite a few times with excellent results... I've NEVER had a set leak at the head, and only one leaked at the collector.. which i blame myself for never retorqueing them.. all of that using regular cheesy header gaskets... 3 bolt collectors are the least desirable design, tho doable if you keep your eye on em.. ball/socket are nice, but i run slip-fit whenever possible... bulletproof....
