hedders and oil dipstick
Discussion in 'The Garage' started by George_Pimpdaddy, May 10, 2006.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    so on my 89 blazer i installed a set of hedman hedders and now my factory oil stick wont line up good to the hole in the block so what have some of you guys done to solve this? thanks
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    same problem here
    looking at the bracket it looks like you can trim a bunch of the bottom, and it will line up, i just havent gotten that far yet
  3. George_Pimpdaddy
    Oct 17, 2002
    1,306
    you would think that more people would have had this problem i wonder if hedman has a solution?
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    there's a cheaper solution. grab the tube, and bend it so that it clears. my Edelbrocks used a "P" shaped clamp to hold the dipstick tube to the header tube.
  6. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    I put Lokar on mine.
  7. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    Look at ZZ4 dipsticks. They might work.
  8. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    My Afterburner headers caused the same problem. I just "modified" the bracket a little and bent it and cut a little off the bottom. Worked for me, but I dont know what shape your headers are.
    -Harrison
  9. George_Pimpdaddy
    Oct 17, 2002
    1,306
    i think i got it solved i called the local partsource and they ordered me in a flexable dipstick for my motor gonna cost like $35 but it will be in tomorrow only thing is its only like 7" long outta the block so its a shorter stick but should be better than i have it now
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i cut some of my bracket off, still wouldn't work, the header flange was to thick
    so i took one of the bolts out of my center bolt valve covers and bet the bracket to fit
    works perfect
  11. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    On my big block, I lost the factory dipstick, put in a lokar, and since I have a bodylift, I bolted it to the top of the frame rail, poking out into the fenderwell. Easy to check the oil without popping the hood, and aint had any problems out of it.
  12. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Just bend the tube..
