Heep body on Blazer frame
Discussion in 'The Garage' started by Brady, Mar 16, 2002.
  1. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I have been toying with putting a Cj-5 body on my '73 Blazer frame.I already have a '75 CJ5 sitting that I was planning on building.But I like the wheelbase and width of my Blazer.Just don't like the width of the body.It is getting narrower though.I was thinking of leaving the heep body stock and adding a box behind to fill the space.Since the overall lengths are different.What do you guys think?I just think this might be easier and cheaper than building the heep.If I build the heep I would be starting from scratch.It has no drivetrain right now.And the Blazer is running and working great.Just the body is hammered from 1 too many tight spots!Brady
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Personaly If I was to build another body swap I would use a stock frame and just transfer the drivetrain ove, build ne mounts for all the componants.
    things you have to look at:
    front approach and engine room
    rear departure and gas tank
    engine to fire wall clearence
    But for a quick swap and a toy only, I'd just throw that body on it and wheel it,LOL.
  3. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    BLASPHEMY!
  4. Brady
    May 6, 2000
    628
    Parachute,Co
    My plans were to put all chevy under the Heep.But I don't like the short wheelbase.I like the wheelbase of the blazer.Just the body is tooooo wide for the trails I like to do.I have been wheeling this Blazer for 3 years and every year it is getting rougher and rougher as I hit harder trails.I did 21 Road last Sat.And put a dent in every corner of it!Brady
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    At least get an S10 body for it! A P/U long bed may be about right.
  6. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    A CJ-8 might fit better than a CJ-5. You could always cut the 5 behind the front seat and splice in some sheet metal. Build kind of a home-brew CJ-6. Either that or loose some of the lower sheet metal on the K5. Thats what I'm doing.
  7. Brady
    May 6, 2000
    628
    Parachute,Co
    A S-10 would work but I have the heep body already.I thought about cutting the Blazer body but it still is too wide.I was thinking of leaving the heep body stock than putting a little flat bed behind it.Brady
  8. Brady
    May 6, 2000
    628
    Parachute,Co
    Oh yeah a CJ-8 or CJ-6 would be the ticket but have you tried to find one!There just not out there unless you want to spend a bunch of cash.
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    If its already bashed up, who cares. Let it ride. OR take a look at MTPockets rig. Its in the project vehicles page. He had a sweet looking ride and went all happy w/ the sawzall. Now it is mean lookin. If the wheels are still the widest point of the rig, a narrower body wont be of much help. At least that way the body will be a slider of some sort to keep you from hanging up on the tires. Battle scars.
    I personally am into mud but I do understand the rock crawling squeezing between 2 rocks or trees side of our sport too.
  10. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Putting a JHEEP body on a Blazer frame?
    that would be a waste of a perfectly good frame
  11. Brady
    May 6, 2000
    628
    Parachute,Co
    It already is chopped up some what.36" swampers with 2.5" of lift and no rub.I also started chopping the front below the headlights yesterday.Tired of the body hitting before the tires.Pulling the hood and planning on building a lighter one from aluminum diamond plate.No inner fenders now also.As far as a narrower body not helping it does help a bunch when the tire goes over a big rock and the rocker just drops on it and hangs up.
  12. Brady
    May 6, 2000
    628
    Parachute,Co
    Also part of the reason for doing this is for the weight loss I would have.A jeep body is much lighter than a Blazer.
  13. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I've got a powdercoated k5 frame kicking around and a friend had a decent CJ body so we were gonna build a hybrid like your talking about. Our plans were to leave the CJ body mostly stock and cut the frame down as much as we could, then tube the entire thing with a full cage like a rockbuggy. The CJ fenders would have been cut so that the longer wheel base wouldn't be a problem with running 44's and a 4" lift. We got to busy with other projects though, and the 44's ended up under a '57 Willy's pickup.
  14. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    theres one in four wheeler april 02 pg 50
  15. BADASSBLAZE
    BADASSBLAZE Registered Member
    Jul 20, 2001
    63
    Pollock Pines, California
    Forget the Heep body...Extracab S10 cab on a K5 frame, baby!
  16. Brady
    May 6, 2000
    628
    Parachute,Co
    Need a rear seat for the two boys.
  17. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I think the wheel base of an S-10 blazer is 104" and the K5 is 106?? this would work pretty good, well if you had an S-10 body /forums/images/icons/smile.gif
  18. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    s-10 standard cab short box is 107"
    73 to 91 blazer 106.5" PDC if you ask me.
