HEI Advance Curve in a BBC Blazer
Discussion in 'The Garage' started by rcamacho, Oct 18, 2004.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I'm running a 402 w/ .5" roller cam in an '87. The HEI needs an advance curve and shim bac, so I'm diving in this evening. I'm planning on using the baseline advance kit from Mr. Gasket w/ 22degrees by 3000 RPM. The goal is 12 deg initial @750 rpm w/ 32 total (init + cent) by 3000 rpm.
    Feedback/recommendations?
    The existing curve is rediculous, it does not even start advancing until about 3K.
  2. rcamacho
    Jul 1, 2004
    1,324
    WA
    Just finished cleaning up the HEI this morning. I used a Mr. Gasket distributor shim kit to bring the end play down from .3" to .025". Since the heads and manifold have been milled, the distributor housing also required shimming to avoid bottoming out in the oil pump drive.
    Regarding the advance curve, the Mr. Gasket cam and weights are junk. The weight bushings would not slide well on the pins. I did however use the silver springs from the kit and now actually have some centrifugal advance. The truck gets up and walks now. /forums/images/graemlins/smile.gif
