HEI Dist +Bat lead Power Requirement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, Nov 6, 2001.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I'm currently redoing all my wiring and had a question regarding the Power Lead that goes to the +bat terminal on the distributor. How many amps does that require? I previously had a 30amp fuse on a 18ga wire going to that which is Mickey Mouse to say the least. I heard it only requires around 5amps or less. Just wanted to verify that. Thanks
    Crawlin the rocks with my K5
    <a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
  2. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I have mine running from a spade terminal on the fuse block that is linked to my ignition Im not sure on what amprage it needs. Just 12 volts. I heard a 12 gauge wire is best.
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
