HEI Distributor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tweetysuarus, Jan 15, 2004.
  1. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Has anybody ever used a Proform Hi-Performance HEI distributor before? Or have you ever heard of it? I just want to know cause I just ordered one through Jeg's for $159.99!
    Proform High Performance HEI Distributor
    100% New Parts!
    These high performance HEI distributor produces a 50,000 volt spark through 7500 rpm, offers true spark alignment for instantaneous voltage response, a high performance advance curve, plus a high performance coil and cap with brass terminals. Also includes a low-saturation ignition module for maximum spark intensity and high output coil. I hope this thing is a decent distributor. /forums/images/graemlins/crazy.gif
    Bill
  2. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    I bought one from them with a vac. advance, it work as good if not better than a new stock one. I upgraded it with an "Accel" coil, cap, and rotor. No problems so far. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  3. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Thanx for the feed back. I hope I have as good luck with it as you have. I do have Accel coil & control module here on my old distributor, so I think I'll salvage those out since they are only a couple of weeks old.
    Bill
  4. lukebaby1
    Dec 16, 2003
    231
    Richmond, Virginia
    If your going to pitch your old distributor, you might consider this. You can pull the guts out of it and get someone you know that has a lathe to machine the gear off down flush to the shaft. Leave the housing intact, makes an excellent oil pump and engine primer if you ever need one. Just install in the manifold like you would the distributor, get a drill and prime away. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif
  5. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    I already have oil primer. And I am going to send out my old distributor to get totally rebuilt with hi-performance parts and have the thing recurved!
    Bill
  6. lukebaby1
    Dec 16, 2003
    231
    Richmond, Virginia
    I just PM'ed you! /forums/images/graemlins/thumb.gif
  7. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I ran one for a long time in my car, only took it out to go msd. I have had the pro form (with msd guts) in my k5 since oct and have had never had any problem with it. I would buy another if I needed one.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You can take the gear off a distributor with a bench grinder. Also, you can remove the advance weights without taking it apart.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    dont ruin a good HEI one to make a tool from, just find an old points type one to do that with /forums/images/graemlins/laugh.gif stock original HEI are going ot get hard to find in the future, and carbs too, only certain number wer emade and their numbers are dropping fast, its hard enoguh to even find a 350 running anymore they all end up actually being a 305
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got one that got trashed when my cam broke in three pieces, I'm gonig to use that one.
  11. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    I agree with don't ruin a good HEI unit! I am rebuilding my old HEI with performance parts.
    Bill
