hei question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by hailey, Dec 18, 2002.
  1. hailey
    hailey Registered Member
    Aug 25, 2002
    32
    chattanooga, tn
    my 72 350 has the stock points ignition. what are the pros and cons (if any) for the hei? what are the best brands, prices, how hard are they to install, is it really worth it... my dad says its not to bother with it, but he is kinda lazy, so... thanks for the help
    hailey
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I dont think that there are any Cons at all. I have updated all of my older vehicles and have never looked back. Basically you just drop it in and set it up like any other dist. and hook up the one power wire too an accesory hookup and go. You could get one from a junkyard.
  3. Nikk
    Nikk Registered Member
    Dec 16, 2002
    34
    Lacrosse, WI
    Check out Summit Racing. I bought one of their GM HEI's that is totaly rebuilt and blue printed. It comes with a hotter coil and a few other upgrades. It also comes with extra springs if you want to dial your advance in to your set up. It comes complete with cap and rotor and it's ready to drop in(I dropped it in right out of the box). It was about $150.00 when I bought mine. Not that a junkyard isnt a good idea but for the money you wont have to worry about any problems. If your on a tighter budget I believe around here a rebuilt HEI from the local parts house is about 50 or 60 bucks(this is a stock replacement with no goodies added on, but it's also a good way to go). Last thing is you can buy a spendier set up but you wont gain much by that, and remember you need a full constant 12 volt source ran to the HEI. Dont use your existing resistor wire you'll have problems if you do. JMO Thanks /forums/images/graemlins/thumb.gif
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I have electronic in mine and have no regrets. I put an accel supercoil and some decent wires on it too. Like a previous poster stated, make sure you use a full 12 volt power source, not the existing wire that powers the points dist. I use R45TS plugs and have had good luck with the system all around.
    John
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i got mine from the j.y. for 15 bucks.put a new cap and rotor and wires and it ran good.rehooked up my msd to it and have had no problems yet except i hooked it up to the stock power wire and burnt out the fusable link.i just rehooked a power wire to the accesory spot on my fuse box and it runs good now.
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    The only con I can think of is that the things don't fit too good in some GM 4x4s. I had to beat the tar out of my firewall so that I had room for the GM large-body HEI. A guy by the name of Dave Ray converts GM points distributors to electronic operation and will set up the advance curve any way you like it. His prices are reasonable and the things look factory enough to be installed in 100 point show cars. All of the parts he uses are available at most auto parts stores, so you won't have any problems finding spare parts if you ever have a problem (unlike with a lot of the aftermarket electronic ignitions).
    I posted about Dave a while back. Do a search for his name and you'll find his email and phone number.
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have a stock HEI from a newer chevy and it works great, Only con is my tach reads to high...
  8. naranja72
    naranja72 1/2 ton status
    Jan 6, 2002
    110
    vancouver, bc, canada
    I had went with the MSD ignition system a few years back. Right away noticed more power and better gas mileage, would definitely recommend this approach if you want to spend the money.
  9. blueturd
    blueturd Registered Member
    Dec 3, 2002
    88
    Arvada, CO
    Be careful to look under the cap if you buy one from the junk yard. Some of the early models are prone to "crossfiring" across the counter weights instead of the breaker points. This can often be fixed by rebuiding it, but the newer models are less likely to do this.
