HEI relay install(PIC'S)
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by BobK, May 26, 2004.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    HEI relay install(PIC\'S)
    I installed a relay to power up my HEI today.
    Pretty easy install.
    I also installed a relay for my heated o2 sensor.
    Here are a couple pic's.
    ALL the pic's can be viewed HERE
    The relays I used.rated at 40 amps.They are DPDT(Double Pole Double Throw) relays.$3.00 each at my local electronics wharehouse.
    Ran these wire from a existing IGN. splice at the IGN. switch to trigger the relays on.
    Here is the splice I had made at the IGN. switch(kinda hard to see)
    I replace my existing 1 wire o3 sensor with a 3 wire(heated) o2 sensor.Here is the retrofit harness.
    Here's the new 3 wire o2 sensor installed in the drivers exhaust manifold.
    This is the power feed to the relays.Red goes to the HEI relay(12g wire).Blue goes to the o2 sensor relay(16g wire).
    The circuit is protected by a 12g fusable link(light blue wire).
    All hooked up now.
    Here's the voltage now being sent to my HEI coil 14.12volts.
    Should produce a nice arc!
    Took me an afternoon to do this project (pissed around alot though) and maybe $10.00 in materials.
  2. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Re: HEI relay install(PIC\'S)
    I'm electrically challanged so bear with me - does the relay help in getting the better voltage reading. I've always just seen the HEI wired direct - this is a better way I take it?
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    The more voltage you can supply the HEI the better it performs.
    Better/hotter spark...stuff like that. /forums/images/graemlins/grin.gif
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Looks like you did a nice and clean job!! /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
