HEI swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, May 27, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Im going to swap an HEI into my 73 k5 and was wondering if i have to get a new wire from the fuse block on the engine side. Ive heard that these are sometimes resistance wires with only 6 volts and that HEI's need 12v. My truck has a ballast resistor so would this mean that it has 12v and the resistor lowers it to 6v? any help would be great. Thanks
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I just sold a 74 pickup this evening. It had been converted over. I would have gone out and checked it for you. I do remember that the feed for the dist had been spliced. Sorry I can't tell you more.
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Yes, you need a good 12 volt "ignition" source wire. The resistance wire doesn't drop it to 6V, but your HEI will like a good 12 much better. I can see where I got mine from if ya need it.
    Michael
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  4. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    Yeah, if you could check it out, that would be really helpful, im also not quite sure how i would run a wire through the fuse block. thanks
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Michael is right. You will need to run a wire to the fuse block. Put a female connector on some 12-14 gauge wire, plug that end in the dist. cap and run the wire through the firewall and tap it into a fuse that only has power when the key is in the run position.
    '73 K5
    Chevy good...Ford bad
  6. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    That sounds good. Thanks for the help
  7. Michael
    1,576
    Sherman, Texas
    xnoahx, sorry it took me awhile to get back. I ran a wire from the distributor....snaked it thru the grommet where the speedo cable comes thru the firewall.....then down to the fuse box. Right about in the center there is a male spade terminal marked "IGN".
    Michael[​IMG]
  8. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I converted my 73 k20 from points to HEI.
    The points are supposed to recieve a 6V wire. There IS a resistor inline. Simplt follow the power wire from the coil to the fuse block and you you will find it. I cut the resistor out and spliced the wire together, then dropped in my HEI. Runs great.
    -- Mike
