HEI to Mallory unilite conversion
Discussion in 'The Garage' started by nova, Mar 11, 2007.
  1. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    I have a 77 blazer with a HEI in it. I just picked up a new unilite from a buddy for free:D . I also picked up a msd 6al ing. box from jegs. I'm looking to install the unilite but there is no instructions on how to go from hei to a points style of distributer. The msd ing. box is easy once i figure out how to install the unilite to the factory hei wires. And then there is the question of a ballist resistor or a capasitor, do i need them?:confused:
    Any help out there on this subject?
  2. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    not tryin to start something but why are u wantin to put in a points style, the hei is a way better dist, i would just put the msd 6al on the hei, its easy and a good upgrade to your hei, the hei is one good thing about gm imo.
  3. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    My HEI took a dump and the Mallory unilite like i said was free. There is no points to wear out in a unilite it has some photo optic infrared LED system deal in place of the points, it and a blaster 2 offroad coil puts out just as much as an HEI.
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The unilite electrics go bad often. Also you would have to change plug wires or at least the cap end of them. The GM modules are cheap and easy to replace. Just replace the GM module and install the MSD box on your HEI and you're set.
    EDIT: Before anyone says anything about a GM module going bad it is way easier to walk into any parts store and buy a GM module over a unilite module.
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    X2
    After my third unilite unit failed (first two were replaced under warranty) I switched back to points until I rounded up the HEI stuff to convert. When they failed, there was NO warning.....truck just wouldn't start.:mad:
    Unilites are junk......and HEI parts can be purchased just about anywhere.:deal:
  6. dbozman
    dbozman 1/2 ton status
    Nov 11, 2006
    115
    Phoenix
    Free or not, no way I'd swap out HEI for a unilite. Had one in an old project GTO of mine; piece of junk. The electronics inside are expensive and die often with no warning. You can get the proper module to install in your HEI cap to run the 6AL box. That's what I'd do.
    d
  7. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    I concur...... Never been a fan of Unilites...
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Another No Unilite vote.
    I believe MSD makes a harness that by-passes the stock HEI module so that the 6A is triggered directly by the HEI pick-up coil, no need for the stock HEI module. Look up MSD's page & dig into their on-line tech manuals.
    I just did something like this on Javier's race truck, but I don't recommend doing it the way I did as you can't back up. With the MSD harness you can go back to stock.
  9. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    That is correct. I have mine set up that way.:D
  10. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    Thanks everyone for the info I'll check into it
  11. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    NTSQD is right. The MSD DOES replace the GM module. IMO the Unilites are crap.
    Go with the MSD.
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I used to really like Unilites they were very dependable when Mallory made them. About 10 years ago Mallory was bought out by Mr Gasket and quality went down the drain. I knew a guy that worked at the Mallory plant when Mr Gasket took over. He said they started taking short cuts and bought cheap materials. Got rid of all the old employees that were experienced. They could care less about quality Mallory ignitions used to have . All they cared about was using the name.
    Its strange... Mr Gasket also owns Jacobs ign, and Accel. I dont have a high oppion of either of them either.
    Maby thats why MSD is recognized as the best Ign stuff around
  13. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    FWIW I've had good luck with the Crane HI-6 stuff (A direct competitor to the MSD 6). I like that their rev limiter is built-in instead of being yet another space consuming box with more wire connections to fail.
  14. Slapperbar
    Nov 29, 2005
    2,747
    3
    6-AL is built in. That's why there's an L in the name. I've seen two engines detonated that were directly caused by the Crane ignition.
  15. 85mudbogger
    Feb 5, 2007
    226
    missouri
    yes it just uses a rpm pill u plug in the bottom of the box for the rev limiter, u buy the pills seperately and i comes in like a 4 or 5 pack or somthin or other, very easy to change and very easy to hook up to your hei too, took me longer to mount it than to hook all the wires up
  16. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    And the situation was such that an MSD being there instead would not have done the same thing? Were both Crane's of the HI- series or the older Stinger XR700 series? The XR's were an ancient design, & not a lot better than points.
    As to the rev limiter, the Crane is still a better bet. There are no pills to buy or have fall out. They use a pair of small rotary switches.
    Better than all of the above are the M&W Ignitions, but like an EFI system you're going to have some development time in plotting an ignition map. Their catalog pdf has a lot of interesting info in. We use one of their ignitions on the dyno at work.
  17. Slapperbar
    Nov 29, 2005
    2,747
    3
    The engine failures were directly related to the ignition, and yes a dial is more convenient. BTW I've never heard of a pill falling out, not that it's never happened.
  18. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    What I'm asking is were those failures the result of a problem unique to the ignitions used, or could any ignition system have caused those failures?
    To say those engines failed due to an ignition problem, and then say that Crane ignitions were used and therefor Crane ignitions are bad isn't fair to Crane or to those reading this thread.
    If the Crane units had a unique failure that any other ignition system most likely would not have had in that application, then you can put the engine failure blame on the ignition brand itself.
  19. Slapperbar
    Nov 29, 2005
    2,747
    3
    From what I was told by the Dyno operator it was the Crane ignition only.
  20. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I should have asked this in my last post, what sort of failure(s) were they?
