HEI Upgrade on 72K5
Discussion in 'The Garage' started by 72k5chicago, Nov 16, 2006.
  1. 72k5chicago
    72k5chicago Registered Member
    Jun 1, 2005
    12
    chicago
    Does anyone have any advise for swapping out the old points distributor on my 72K5 (350 sb) to a new HEI distributor? Anyone already done this? I have been told its not really that hard, but I thought I'd "ask the audience" and see if there were any tips out there for making this go smoother first. Thanks!
  2. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    Pretty much a easy install. Just give the HEI a 12 volt key on(including power when cranking) power wire. One thing though, if you have an internal regulated alt. it may keep running when you turn the key off. I have had this happen on my 69 firebird and my 69 chevelle. You need to run a resistor in the field wire to the alt, otherwise the slight amount of power feeding back through the wire with keep the HEI going.Dan
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    On my 70 K5, there is a terminal in the fuse box marked "ign". I just ran 12 gauge wire from there to the hot feed of the HEI. I left the original ignition wires in place and just taped up the hot feed to the coil. Then you disconnect the 2nd small wire coming off the starter solenoid that only shows 12V when the key is on start.
  4. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    New dizzy, new wires, plug in.
    Do NOT use the old power wire to the dizzy, though, as it has a resistor in it which will make the truck run like poo, if at all =)) Ask me how I know (previous owner, grrr)
    As others have said, run a new, 10-12 AWG from the fuse box to the dizzy, so it's powered only in RUN and START, and you'll be fine.
    -- A
