HEI Waterproofing
Discussion in 'The Garage' started by sandy78, Nov 29, 2003.
  1. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    Any suggestions for sealing up an HEI? Everytime I play in the water I end up with a little inside the distributor. Not enough to kill it, just enough to make it run bad 'til I clean it out.
  2. IronMan
    IronMan 1/2 ton status
    Nov 16, 2002
    223
    Bay Area, CA
    You can run a bead of silicone around the base between the cap and the distributor. Make sure that it still has a vent though. Use a valve such as the one on a axel, it will let air out, but keep dirt and water from entering in.
  3. sandy78
    Nov 28, 2002
    84
    Utah
    Thanks for the reply. If you go the silicone route, how do you handle the vacuum advance rod?
  4. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    Don't use silicone, use die electric grease instead. It is much easier to clean off if need be and it is water proof. As for sealing the vacuum advance rod, you should not put anything on it or it may not work anymore.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    dielectric grease could get pricey though if you need to keep reapplying,
    normally HEI caps do good job of keeping water out,
    i would use something like chassis grease, etc. i fi need to use anything at all, be cheaper and would wipe off too.
  6. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    I'm not sure where you are buying it from but around here you can get a large size sqeeze tube like the size of silicone for about $4.00, that doesn't sound too pricey to me. /forums/images/graemlins/thinking.gif
  7. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    I just got a spray can of some white (lithium) grease from Wal-mart for 2 bucks. That should work too. It's the same stuff we use on the door locks.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Clear dielectric grease sells for like $4 a can at an auto parts store and its a pretty big can.
  9. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I just use regular Vaseline... or you can use the baby powder scent Vaseline too I suppose /forums/images/graemlins/smile.gif.
    Anything will work as long as it repels water, and with the grease type stuff, if there is ever any pressure build up, it will just blow itself out thru anywhere.
    Mike
  10. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    What ever you use make sure it's not conductive. That is what dielectric grease is good for. Chassis grease is a conducter so I wouldn't use it I don't know about vasoline or any of the others mentioned just use caution.
  11. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Use the sealing 'clay' used on HVAC systems. Wish I could remember the trade name. That's what the dezert racer I crew on uses to keep the dust out of it's dizzy. It's also sometimes sold for sealing seams in automotive stuff. It never hardens so you can just push it back into place after R&Ring the cap. It also doesn't pick up dirt like grease will, so it doesn't turn into a huge mess.
    For that matter, Play-D'oh would work for a while until it hardened.
  12. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    that stuff's called duct-seal. Probably would work pretty good. A pretty big chunk should only be a few $$. Hardware stores should have it, Home Depot for sure.
  13. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Why not use a marine HEI cap!
  14. Stroked72Blazer
    Nov 9, 2002
    352
    Little Rock, AR
    I haven't checked on that but usually when a part has the word marine in front of it expect to pay about 5 times as much.
