Hei
Discussion in 'The Garage' started by DavidB, Jul 30, 2006.
  1. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Aren't you not supposed to disconnect plug wires with it running to see which one is missing?
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    You can do it that way, just make sure you are wearing thick gloves in case it is a bad wire. Just find the one that doesn't make much or any change when disconnected and that's your culprit.
  3. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    According to GM..
    All my GM manuals claim it can pop the module by leaving one wire off,or being burnt thru,etc..but real world experience is usually different than textbooks..
    If the plug wire is far from a ground,and enough voltage builds up to finally jump the gap,thats the "surge" that will possibly pop the module..
    I've seen hundreds of cars come in skipping due to plug wires roasted on headers,or just plain fell off,and the car keeps right on running,though poorly..in theory its quite possible,but they rarely seem to fail that often..
    It's like the "test" to see if your alternator is charging,by pulling off one battery cable..it can pop the diodes doing that--but I've seen guys do it for 20 years,and only rarely does it cause diode failure..:crazy:
