Hei
Discussion in 'The Garage' started by jeff l, Oct 26, 2006.
  1. jeff l
    jeff l 1/2 ton status
    Jun 13, 2006
    104
    New Orleans
    I am having problems w/ mine. and am starting to shop around does anybody recommend a certain brand or a high performance HEI. or does it not really matter.
  2. goldwing2000
    goldwing2000 Guest
    Are you looking to replace the entire distributor or just the HEI coil?
    Just the coil, get an accel
    Entire unit, MSD or Mallory are both good.
  3. jeff l
    Jun 13, 2006
    104
    New Orleans
    the entire distributor /I will check those out --thanks
  4. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Not sure what application you are looking for.... so it's hard to answer other than my experience.
    I rebuilt my HEI for my Blazer with the MSD Cap/Rotor/Coil/in-cap Module kit (about $150).
    http://www.msdignition.com/dist_45.htm
    I then had to get a new casting (junkyard $20) because my bushing was shot. Add a new pickup coil (cracked - $19) and then I had to shim the length (shim kit $5). I then splurged and put an adjustable vacuum advance in (another $20). All over the course of several weeks..... and I'm not even sure the MSD upgrade was worth a whole lot since I'll never rev above 5K RPM..... augh.
    If I had it all to do over again, I'd jump on Summit's website and pick up one of the pre-built HEI's on there:
    http://store.summitracing.com/egnsearch.asp?Ns=P_SRE_DisplayPrice%7C0&N=700+4294881256+115&Ntt=HEI&Ntk=KeywordSearch&rsview=sku&RC=10
    Just make sure you get one with a coil (I think the cheaper ones are w/o a coil)
    That's my $0.02.
    -ben
  5. BigBen
    Nov 14, 2002
    1,194
    Grand Haven, MI
    If you were in the market for a little more $$... you might look at these:
    (They claim to match the advance to your engine/application)
    http://www.performancedistributors.com/gmssdui.htm
    I've read some good things about them in the hot-rodding magazines, but can't give you any personal experience stories.
  6. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    I rebuilt mine with a pertronics kit from summitt. Can't remember the exact price, but I wanna say around 60. Easy to do also.
  7. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
