Height proportion valve.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tomseviltwin, Nov 11, 2002.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    My v20 suburban is blessed with a hieght proportion valve. I am going to lift about 6" and switch to 14ff at the same time. Should I leave it in, take it out or what? I will be using much softer springs so It wouldn't probably be set right anyway. Any oppinions. Also, if I go to disk brakes, this isn't the valve at issue with many who've done that swap is it?
    Mechanically disinclined people want to know.
    tom /forums/images/graemlins/burb.gif
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I recommend just using a flat piece of steel and lengthining the piece that connects the arm with the valve...that way, you'll still be able to utilize the valve.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you go with soft springs, and disc brakes you will most definitely need to ditch it.
    It will not work properly.
  4. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Thanks for your thoughts. I'll try lengthening the extension first and see how it works, and dump it if I need to. Disk brakes are still a futrure mod.
    tom
