heli-coil drilling
Discussion in 'The Garage' started by jasonkh2tg, Aug 17, 2003.
  1. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    what size drill will i need for a 7\16" heli-coil and a 1\2" Heli-coil...
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    do u already have the heli coils?? u can buy kits that have everything included in em for pretty cheap.
    NITRO
  3. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    Hope this helps.. /forums/images/graemlins/thumb.gif
    Tap Chart -
    Helicoil Threads
    Tap size ---- Drill size
    2-56 -------- 3/32
    3-48 -------- #33
    4-40 -------- #31
    4-48 -------- #30
    5-40 -------- #30
    6-32 -------- #25
    6-40 -------- #26
    8-32 -------- #17
    10-24 ------- 13/64
    10-32 ------- #7
    12-24 ------- #2
    1/4-20 ------ 17/64
    1/4-28 ------ G
    5/16-18 ----- Q
    5/16-24 ----- 21/64
    3/8-16 ------ X
    3/8-24 ------ 25/64
    7/16-14 ----- 29/64
    7/16-20 ----- 29/64
    1/2-13 ------ 33/64
    1/2-20 ------ 33/64
  4. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    The best source for drill size is the tap. Get the tap you need and hopefully you will be able to read on the tap what size you need. You can get wrong info from others that can cause you trouble later. My 7/16" NF tap says on the side "drill size - 25/64"." That is what this one says anyway.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Regular taps are not the same as heli coil taps and they use different size drills, most taps regular or heli coil will give the proper drill size for them though.
  6. jasonkh2tg
    Mar 27, 2003
    139
    MPLS MN
    wow thanks for the reply's guys....the (heli-coil) tap chart helped...thanks
  7. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    What is a heli-coil? I have a bunch of heli-coil taps but have no idea what they are for. Thx
