Hell of a time getting bolt off! help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, Sep 2, 2001.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    my NP208 is leaking. Now usually I go to get it "Topped off" and most places do it for free. But now i went out there to top it off myself and the damn thing is stripped all to hell. What is the best way to get the top bolt off? I have tried vice grips, pipe wrench and no such luck. Thanks....
    Surfing is Life...
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    They make special pliers for rounded off nuts and bolts. They work 100 times better than vice grips. The are not a locking plier like vice grips, but the ends look like part of a circle. You can pick them up for $10 about anywhere. Sorry kind of hard to explain. Another way would be like the ends were bent down.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    <font color=red>BIG F-----G HAMMER!!!!!</font color=red>
    It works for everything else[​IMG][​IMG]
    <font color=blue>Esteban</font color=blue>
    <font color=red></font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/Estebans-album>Take A Gander At My Truck Here.</a>
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You can take a grinder or file under there, and make flats on it to grab hold of it with a crescent wrench, or if worse comes to worse, just tack a nut on it. When you put on the new one, make sure to coat the threads with anti-seize.
    1 tequila 2 tequila 3 tequila Floor
    &lt;a target="_blank" href=http://pugsley.alloffroad.com&gt;pugsley.alloffroad.com&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by Pugsley on 09/02/01 04:50 PM.</FONT></P>
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I had a problem nut once. Got my Craftsman hand tools out, found the next size smaller socket. Pounded it on the bolt. Bolt came right off. Then you have to get the bolt out of the socket. Note...use LIFETIME warranty tools....it can beat the [censored] out of a socket!!
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    If it wasn't for bad luck I would have no luck at all!!
  6. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    if you take a torch and heat it then let it cool it will come out
    4x4k20
