Hell YEAH! Got a Dana 60 on the way !!!!
Discussion in 'The Garage' started by BrianDamage, Apr 27, 2006.
  1. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    Well, I posted the other day about getting the 14 bolt ff and how I was going to have to go without a front shaft because of the change in gear ratios.
    I fixed that problem this morning and go t a rebuilt dana 60 coming too! :D
    (note to the ladies: I MAY be single after the wife finds out :wink1: )
    dayum, I'm STOKED. I can't wait.
    It'll probaly be later this summer before I can affford to swap them out...depending on my tire situation. Here's my situation: I am currently running 33x12.5's on the stock rims (what are they, like 15x8.5's? something like that?)
    I want to eventually run 35's. I think my truck has had a 2.5 " lift installed on it, because the 33's have plenty of room. The thing is, that in order to keep the peace around here, I need to do this a little here and a little there to keep the wife happy.
    So, can I run my current 33x12.5's on a set of 15x10 rims? I would like to just buy some rims now, run the rest of the tread off of these tires this year, and then next year buy some 35's, along with a 4" lift. I'd hate to buy some cheap 15x8's now, only to buy 15x 10's later.
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    congrats on the new beef
    10" rims are perfectly fine for a 12.50 tire, doesnt matter if its 33" or 35". infact, tire manufacturers usually say to use at least a 8.5" rims for 12.50 tires
  3. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    convert that rear 14bolt to disc and you should be able to run your current tires (unless your rims arent 8 lug...) :wink1:
  4. BrianDamage
    May 14, 2001
    753
    Alabama
    both axles have disc and 8 lugs, so I gotta get new rims
