Hello, My buddy has a 2x4 he wants to lift, please help>>
Discussion in '1936-Present Suburban' started by Burt4x4, Mar 27, 2002.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    My friend has an 86 2x4 Sub with 33s. He wants to lift it 2" or 3" but has not been able to find a lift kit for it/forums/images/icons/frown.gif
    Do any of you all know were he can find a lift kit for a 1986 2x4 Suburban?
    Thanks for your time!
    Burt
  2. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
  3. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    if its a 1/2 ton, then he should be able to get a standard pickup truck front end lift from Fabtech. if its a 3/4 ton, then he's probably screwed, unless he wants to fab a setup himself. I've given up looking for a 3/4 ton lift kit for my burb. another option might be to find a wrecked 1 ton pickup ( 2wd) and pulling the components off that... they made them ride about 2 inches higher then a 3/4 ton, or 1/2 ton. that'll give you about the lift you're looking for. you can also get newer springs up front from a 4x4 shop installed. this'll help lift the front end a little, but you're still really limited in what you can do with the 3/4 ton.
    -Rich
