Hello?!?!
Discussion in '1936-Present Suburban' started by dleroy43, Nov 22, 2005.
  1. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    whats up burb owners!!
    this place has been kinda slow lately so whats everyone up to?
    I installed my rock lights today and my winch last weekend
    just making sure not everyone is selling their burb
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    NICE...... what else are you going to be doning the your burb???
    I'm waiting for my winter break in 3 weeks and I'll be off for 6 weeks :D And then it's time for :hack: :weld: :grind: on the burb........
    I'm going to be clocking the transfer case flat.
    15" travel shocks up front.
    relocate front brake lines.
    0rates front and back.
    new exhaust system.
    upgrades to the TBI.
    plus some body work.
    and what ever else I can think of.
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Looks like a UFO, who needs headlights. Did you use tube lights or floods? All the Subterainians are over at 73-91 Sub/Truck. Yeah,I'm doing engine swap along with X-case rotate, over the Holiday break, but only get 12/16 thru 1/2 off.
  4. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Well. I am installing 3/4 ton running gear, new wheels. selling off old 6 ug wheels and 4" kit I never installed.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I've been busy getting the new motor into the burb. Finally fired the ole girl up today for the first time and DAYUM does it sound good :D still have to time it.
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    almost sold my burb but it's getting the full treatment for the job of daily driver and tow rig.
    before april it is gonna be transformed from a
    6.2 th400 -241 with 10 and 14sf with a lame 4" lift
    in to a
    383 sm465 208 hydro d44 and van width 14 ff with disc with 3" body and 4" new springs front and rear crossover steering
    full howlin off road treatment:
    steering brace
    rear shocks
    anti wrap bar
    belly pan
    engine crossmember
    also:
    clocked 208
    multi mount winch
    should keep me busy
    oh and finish my willys meanwhile
  7. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    those are just $15 wally mart fog lights but it does look like a ufo, LOL
    I have some other 56" springs from a 3/4T burb to put on before I go back to Germany for a few weeks.
    Hopefully when I get back we can start our snoe runs :D if it ever gets below 70 :crazy:
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Ho, let me know, I'd be up for snow, after New Year. Had the chains for a year, been waiting to try them out.:D
  9. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Are you putting on rear steer?:confused:
  10. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I think that I will just take it out and see what breaks. Then I will know where the weak point is. :D Those rock lights look great. :waytogo:
  11. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    heres the pic of my winch :D
  12. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I just bought a 91 burb. After tinkering on it for a couple of weeks, it runs. Bad transmission leak though. The front and rear air works. I haven't had a vehicle with A/C in a long time. It will stay stock and be my DD and tow vehicle for my Blazer.
    The PO had spent alot of time and money trying to get it running and he finally gave up and sold it to me for $600.00. I spent less than a hundred bucks to fix it so now I have a sweet Burban 4x4 for a total of seven hundred dollars. :D :D :D :D :D :D :D
  13. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Without SFA, oh well, for that price you could convert and still be way $$ ahead.:D
  14. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,036
    1,095
    Dallas
    I'm graduating in a month. Truck progress will resume at that time. :D
  15. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,856
    282
    Truckee, CA
    Um, 91 burb and blazer were last year of SFA.......
    and if its a 2500, its got a 4l80e :bow:
    good score!
  16. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Year: 1991 Production Total: 7,332
    Base Price: 17,590 Weight: 4,507
    Wheel Base: 106.5 in. Fuel Tank Capacity: 26-gallon/31- gallon
    Length: 184.8 in. Height: 73.4 in.
    Std. Engine, (HP):
    OHV Eight-cylinder 350 cid. (210) @ 4000 rpm
    Opt. Engine, (HP):
    OHV Diesel Eight-cylinder 379 cid. (130) @ 3600 rpm
    Rear Axle:
    GM Corporate 10-bolt (8.5-in. 1.28 Axle Dia. 30 Spline)
    Front Axle:
    Transmission (M):
    SM465 4 spd. (6.55:1 First Gear)
    Transmission (A):
    4L60 * (3.06:1 First Gear)
    Transfer Case (M):
    NP241 (2.72:1 Low Range)
    Transfer Case (A):
    Notes:
    * The 700R4 was re-named to 4L60 in 1991.
    The TBI (throttle body injection) system used on the Blazer's standard 5.7-liter V-8 had longer throttle shaft bearings, new throttle return springs, and improved fuel mixture distribution. The 5.7-liter V-8 also had new heavy-duty intake valves and powdered metal camshaft sprockets.
    Standard on all engines was a lighter more powerful 100-amp CS130 alternator.
    Two new exterior colors, Brilliant Blue and Slate Metallic were offered.
    Blazers featured a steel half-cab with an integral roll bar built into the steel front compartment roof and lock pillar structures.
    Sorry, just had to do it. K5 specs, but you get the idea.
  17. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Looks Awesome. :bow: :bow:
    How about some from underneath looking up at how/where the lights are mounted?
  18. one ton burb
    one ton burb 1/2 ton status
    Nov 15, 2003
    119
    Ontario, Canada
    well my project is on hold till spring, when that comes around i'm doing a body swap to a better body that is not rotted out, dana 60 will be going in as well as a sm465 /np205, will be running 4.56's and some 37's also going to put a 6 inch lift under her, and maybe get it painted all black :D
  19. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Your project is awsome. When you get through, the tire companies should come and ask you to test their tires cause the only thing that could stop the K36 is tread.:bow: A Burb with RSW will be extreme Kool, just like a Hook-n-ladder. Hey, maybe we should start naming these things in that convention, K36 is 4X, 1 ton, 06 body; mine is 1/2 ton so K16. An abbreviated configuration ID code.:confused:
  20. AgDieseler
    Jan 25, 2001
    1,036
    1,095
    Dallas
    My dad calls my sub the M1A1. :laugh:
