HELP!!!!!!!!1 pt 2
Discussion in 'Pacific Region' started by LiftedAssDodge, May 22, 2002.
  1. LiftedAssDodge
    LiftedAssDodge 1/2 ton status
    Apr 8, 2002
    412
    East Bay Area, ca
    ok, i figured it out, i blew a tooth of pinion i think, cause i looked at the teeth on the ring and they look fine, and i opened the diff and a tooth fell out, soooooo whos home and up to helping me change my gears tonight? anyone .... please
  2. LiftedAssDodge
    Apr 8, 2002
    412
    East Bay Area, ca
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Time to throw it away and get a new truck,The cost of the gears will far exceed the value of it /forums/images/icons/laugh.gif
    Maybe an axle shop or a dealer in your area might have those on the shelf.
  4. LiftedAssDodge
    Apr 8, 2002
    412
    East Bay Area, ca
    ummm most dealers dont carry 456 gears homeboy, and axle shops, hmmmm good idea
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
  6. shewheeler
    shewheeler 1/2 ton status
    May 4, 2001
    3,384
    Hollister, CA
    hmmm, maybe if you put it under your pillow, the tooth fairy will help you? /forums/images/icons/wink.gif
  7. LiftedAssDodge
    Apr 8, 2002
    412
    East Bay Area, ca
    actually just called that place, ring pinion daymn like $77 cheaper than 4 wheel parts and be here in 2 days
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
  9. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    That's pretty funny..LOL /forums/images/icons/smile.gif
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    It's certainly a tooth...But it kinda looks like a ring gear tooth. lol, Anyways....You really might want to look into havin a shop do the work for ya. Unless you feel comfy with dial indicators, ft-lb and in-lb torque wrenches, setting backlash, reading the pattern, bearing preload. ect ect. It's NOT a smiple thing. If you lived in my town or atleast a bit closer, I'd help ya out...I just set up the gears in my rig. Hope it works out for ya.
  11. LiftedAssDodge
    Apr 8, 2002
    412
    East Bay Area, ca
    well hell hehe, too bad i dont live in bumfuct, but thanks for the offer, you guyz rock, i changed the locker before so this is the same basic thing, hope to be runnin tomorrow
  12. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    But maybe that's the reason you have a broken tooth on it now, cause you changed the wear pattern when you put the locker in.
  13. LiftedAssDodge
    Apr 8, 2002
    412
    East Bay Area, ca
    nah i had the preload and backlash set in that days ago, and it was only a couple thousandths off, guy saidi really didnt even need it
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmmm, If you are changing out your gear set with a new set, then no, it's not basically the same as doin the locker. When ya did the locker did you remove the pinion gear? I hope not. But now you have too. You have to re set everything again. Pinion depth, pinion bearing preload, and back lash. You can't just stick the new ring and pinion in there and hope it will be correct. The new gear set might have different tolerances then the old stuff....A few thousenths here and a few thoudsenths there makes a difference. For example- The back lash spec for my 12 bolt is .006-.010. Thats only 4 thousands of an inch difference.
    Anyways, Here are the specs for your truck. Asmumming its a Chrysler 9 1/4.
    Pinion bearing pre-load= 14-19 In-lb's
    Backlash= .006-.010
    Ring gear bolt torque= 65 Ft-lb's
    Bearing cap torque= 75 Ft-lb's
    All these specs came from Yukon Gear's Installation Kit Instructions.
  15. Ryan B.
    Jul 18, 2001
    5,693
    CA
    <a target="_blank" href=http://communities.msn.com/Ryans1972Blazer/picsofryansblazer.msnw?action=ShowPhoto&amp;PhotoID=65>That's a tooth Right?</a>
    Been there. /forums/images/icons/cool.gif
