Help! 1972 3/4 ton diffs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JJ85K5, Mar 6, 2002.
  1. JJ85K5
    JJ85K5 Registered Member
    Jan 2, 2002
    21
    So Cal
    I tried doing a search but couldn't find anything. I need help. Thank you in advance for any reply's. I was thinking about buying this guys diff's and was wondering if a 3/4 ton Dana 44 and a 3/4 ton 12 bolt out of a 72 3/4 ton truck would fit under my 1985 K5? The guy said it's 8 lug and came stock with 4.10 gears. He said it was something like a "Camper Special". Is there a such thing? I also heard that the early Dana 44's were not as good as the newer ones. Is that true? I know I would rather go with the bigger Dana 60 and 14 FF but I'm getting a good deal for the two, i think.
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    '72 3/4 ton has an open knuckle (modern design) Dana 44 front, but with smaller bearings than later model trucks. The rear will not be a 12 bolt (1/2 ton only). It will be either an Eaton or a Dana 60.
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    The rear spring perches and shock mounts will need changed for the newer frame.
