HELP 1982 JImmy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ANTMAN, Jan 27, 2001.
  1. ANTMAN
    ANTMAN Registered Member
    Jan 27, 2001
    10
    Raleigh NC
    Can anyone help with this problem? I have a vibration within
    what i think is in the drive train. Have new front and rear U joints put in. New rebuilt 350 replaced old 305 had vibration with it also. Does not vibrate all the time and only between
    35 and 45 mph. does not happen when cold only when vehicle warms up. I am at a loss as well as many mechanics.
    Any ideas out there?
  2. 4x4man
    4x4man Registered Member
    Dec 5, 2000
    10
    bainbridge georgia
    hmmmm,,,,,ever check your tires? do u feel the vibration in the seat or on the steering wheel. if u can feel the vibration in the seat,,,,its usually going to be in the rear. if u feel it in the steering wheel,,,,,its probably going to be in the front.. give me some specifics on the jimmy,,,,,,,,lift? tires? tranny? tcase?,,,,,,,,i might be able to help you
  3. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    check and see if a weight was knocked off the driveshaft when the U-joints were installed, and if they are not greased profusely they will fail, by starting to vibrate first.......js
