HELP- - 2 Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wsudu, Nov 22, 2000.
  1. wsudu
    wsudu Registered Member
    Jun 30, 2000
    43
    Wichita, Kansas
    Hello....I have an 83, and the other day I noticed a vibration when I was driving. This vibration comes only under load....only when I am giving it gas, even a little...When I let off completly and it is rolling it's fine. When it's in netural, it's fine. This vibration picks up with speed...I don't know what it is..Rear end, tranny, transfer case,engine? Last what do you guys with light bars do with the power cables. Where do you put em?....Thanks WSUDU
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Check your U-joints.
    Rene
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I would start with wheel balance and go from there, u joints, drive shaft....... my wheel weights were the culprit but I checked them last. They were all out of balance. I had installed a 3 inch lift also so I dropped the tcase 1 inch and that was a help too. good luck
    creepin' and crawlin'
    Jim
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    Check your u-joints!!!! I had the same problem exactly. Crawl under the truck and shake the drive shaft. If it has play then replace them. Don't forget the clips that come with the u-joints.......my guess is thats the problem......js
  5. FLWIV440
    FLWIV440 Registered Member
    Nov 21, 2000
    32
    Had the same exact problem,after checking the u-joints, took rear differential cover off and guess what,MISSING TEETH! hope this helps.
