Help! 203 TC leak
Discussion in 'The Garage' started by hi pinion, Mar 10, 2006.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    I have a 203 case,,,,,its leaking out of the rear shaft seal real bad,,,,its like parked in a slanted driveway,with the front of the truck facing the garadge,,,, (driveway slants down,from garadge to street) hasn been started since i bought it a few days ago, and even still it leaks all by itself :doah: ,,(btw its mated to a th350, but i dont think it matters any)
    i was eventually gonna do the 400 205 combo, but i wanted to at least drive it temporarily until i gather the set. Whats involved in fixing the leak? Is it worth it to fix the leak? Do i have to drop the pan?
    Also, if a dont have the know how or the tools to fix it,,, how much should i expect to pay a shop to do it?
    Thanks in advance all!
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    if it really is the rear shaft seal, you undo the nut on the yoke, yank the yoke off, pull the seal, press the new seal on, put the yoke on, put the nut on. done.
  3. hi pinion
    Sep 25, 2003
    5,354
    Does this require more than a few Craftsman wrenches?
    I dont have any else but some small hand tools man :crazy:
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Probably need a socket for the nut. Its something like 1 1/4" or some where around that.
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    When I last did one, the seal was a bugger to pull out using the universal "seal removal" tool.
  6. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Why fix it? I find that my '74 leaks lots of places ... I took the top off, that solved the roof leak, but the tranny leaks (some redheaded idiot put it in, didn't do it right :haha: ) and so I just top her off now and again.
    If you aren't fully tool-equipped, I'd just leave it until you have the tools and time and the weather is nice. '203's are cheap, anyway ... I have a part-time one sitting out in my yard, should you need one (but they are freaking HEAVY!)
    -- A
  7. hi pinion
    Sep 25, 2003
    5,354
    THANKS man!:laugh:
    Also, what would a shop charge to fix something like this? If its more than 100 bucks im just gonna let it leak.:D
  8. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I believe the socket is 1 3/16", you can buy a craftsman for not too much money and grind it to fit inside the yoke. You should be able to change the seal for less than $50 parts+tools, takes an hour or two the first time.
