HELP!!!! 700R deisl tranny in a 350 TBI!?!?!?!!? HELLLLLP!
Discussion in 'The Garage' started by zakk, Feb 13, 2003.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    OK, here is the problem:
    I have a friend with a SBC 350 in a 1/2 ton Suburban (electronic Q-jet) and its missing a tranny. Another friend of mine has a 700R that was behind a running diesl in a ~84 Chevy.
    My friend needs to get his 'burban running before my B-Day (Mar. 1) so will this tranny work long term?! it come complete with converter and TV cable at a VERY good price. Any ideas or suggestions needed, cuz we need to install this tranny THIS SUNDAY!! I have heard the shift points are a bit differnet, but will it make a big differnece?!?!?
    HEEEEELP! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    thanks for your immediate comments!!! /forums/images/graemlins/smile.gif /forums/images/graemlins/1zhelp.gif
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    The only difference in the trannys are the govenor. You need to pull out the diesel one, and put a gas one in. If not you will destroy the tranny because it will shift way too early. When I got the tranny in my Burb, GM gave me a diesel one, I tried and tries to set the shift points with the TV cable, but didnt work, and within 1,000 miles I blew it up. The advantage was GM replaced it for free including labor /forums/images/graemlins/grin.gif
    Dan /forums/images/graemlins/burb.gif
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    what did it cost? how hard was it to swap? PM me!!
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The governor weights and springs are located under the round cover on the right side of the tranny. It's about 3 inches in diameter. The diesel tranny is setup to upshift at around 2,800 RPM at wide open throttle. This is WAY to early for a 350 to upshift. /forums/images/graemlins/shocked.gif The tranny for a 350 application will upshift at around 4,500 RPM at wide open throttle. Just take the weights and springs out of the busted tranny from the gas engine and swap them into the tranny from the diesel engine. /forums/images/graemlins/cool.gif
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    /forums/images/graemlins/cool.gif thanks!
  6. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Ok, I'm having a similar problem. I just replaced the 350 with a SB400 in my '89 and it is also shifting way too early now. I've played around with the TV adjustment but can't seem to get it right, is there something I can do with the weights in the tranny to better match the torquey 400?
