HELP! 700r4 question.
Discussion in 'The Garage' started by TEAMROPER, Feb 24, 2007.
  1. TEAMROPER
    TEAMROPER Registered Member
    Aug 8, 2002
    29
    San Diego
    The tranny wont shift from first to second until 3000 rpm's.. Changed the tranny today took out a 700, 208 put in a rebuilt 700 with a 205 TC. Test drove it, same problem. WTF! Blazer was running fine this problem started about a week ago.. Any help would be great. Thanks..
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Have you set the TV cable? If not you will kill that tranny in a matter of minutes.
  3. Bigdawg234
    Bigdawg234 Registered Member
    Apr 11, 2006
    29
    Leechburg, PA
    yep he's right, it either needs set, or its froze up, cause thats what was wrong with mine, grab the cable up by the carb linkage, if it moves freely in and out, and springs back in, then it probably needs set, and bein that you had this problem with 2 transmisions, its most likely that cable.
  4. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    You should definitely get a new TV cable. In order to properly set it you will need a pressure guage installed on your transmission. Bowtie Overdrives sells them as a kit with a 7 foot hose with the guage on the end so you can freely move around. If you dont feel comfortable doing it, go have it done. Otherwise that will be wasted money on a rebuilt tranny.
  5. TEAMROPER
    Aug 8, 2002
    29
    San Diego
    thanks for the help. I did adjust the cable. Same problem. It still moves freely. I pulled the governer and that seemed to be ok. I did read the Bowtie Overdrive instructions and KIND-OF understand the pressure thing. That is who rebuilt it. I was wondering if it is due to it sitting for about a year. I had it rebuilt and put it on the shelf.
  6. Col_Sanders
    Apr 27, 2005
    5,688
    KFC
    Did you buy their relay kit? They dont tell you that you need it unless you ask. Dont know if that would cause your problem. You could just give them a call if they are the ones who built it. They SHOULD help you out.
