Help..72 K5 leans toward driver side
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by codagoshi, Mar 31, 2002.
  1. codagoshi
    codagoshi Registered Member
    Sep 9, 2001
    14
    Iowa
    I own a 72 K5 4x4 with a four inch spring lift, block rear w/33x12's. The truck has 90,000 original miles. It leans toward the drivers side, is this common, is there a fix for it. Has anyone else experienced this. The springs are from superlift, I bought them used, but it appeared to lean before I put the lift on.I would appreciate any help solving this problem. Thanks
  2. BluThndr71JMMY
    BluThndr71JMMY 1/2 ton status
    May 12, 2000
    152
    Tucson, AZ
    Did you check your tire pressure first? I don't mean to be a smart @$$, but I'd start there. If air is OK: Could be body mounts. Could be springs.
  3. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    If it actually was leaning to the drivers side before you replaced the springs, they are pretty much ruled out. Could be body mounts. Has your truck ever been in a severe accident? Bent frame maybe?
    Evan
  4. cleszkie
    cleszkie 1/2 ton status
    Apr 23, 2001
    121
    Santa Ana, CA, USA
    How much do you weigh? Just kidding. I agree with the others. Check your body mounts. I recently replaced the front radiator support mounts on my K5 and it leveled it out (the front clip was leaning to the passenger side).
  5. codagoshi
    Sep 9, 2001
    14
    Iowa
    Thanks for answering my post, guys...the truck may have been in an accident, I purchased it a year ago from the original owner in colorado...The radiator supports are good, no rust, the body cushions do appear to have some bad wear, and I will also take it to a frame shop to see what they think...again, thanks.
  6. BlzrProne17
    BlzrProne17 Registered Member
    Nov 3, 2000
    27
    Wichita, Ks.
    One of my K5 buddies had a problem with his mounts as well. The rear ones were basically non-existant. At first glance I though he was just saggin' really bad. Then I drove it.... OH MY GOD. Ever had one of those near-death driving experences? My advice is to check out the truck and don't take the driver's word for it. Hell I wouldn't even steal my truck because of certain.... steering tricks and post-accident mishaps.
    Matt
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    my body mounts were nonexistant.i changed them and that fixed my problems
