HELP #8 not firing
Discussion in 'The Garage' started by muscle, Jul 4, 2005.
  1. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    Just put together a 400 sm block and finally got to firing her today. all is good except #8 is dead. I have good spark, have swapped wires, plugs. I pulled the valve cover and the valves are opening fine. cant figure out wtf?
    any suggestions on what to do next?
  2. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    No #8
    Check your distibutor cap, and the connections. Make sure the igniton wire is seated right in the cap.
  3. muscle
    May 28, 2000
    408
    Show Low, AZ
    thanks ive done that and confirmed a healthy spark.
  4. LongIslander26
    Jun 25, 2005
    256
    and?
    And it's still not firing? (Hey, you're just up the road a ways from me!) :thinking:
  5. muscle
    May 28, 2000
    408
    Show Low, AZ
    yea i see your in san jaun, lol
  6. LongIslander26
    Jun 25, 2005
    256
    So??
    So you got it running ok now?
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Make sure that the valve lash isn't set too tightly. If the valves can't fully seat when closed, then you'll have no compression in that cylinder.
    If it's a multi-port setup, check to see if the #8 injector is working.
  8. muscle
    May 28, 2000
    408
    Show Low, AZ
    harry i have no compression....just found that out a minute ago. ill check the valve lash now.
  9. muscle
    May 28, 2000
    408
    Show Low, AZ
    And....
    HarryH3 iz da man!
    valve lash too tight on intake valve number eight. when both valves closed i put some compressed air through the spark plug hole and heard air coming out of the carb. Wala! backed off valve lash and can you say instant compression??
    hehe, thanks to all who helped this site rocks!
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Sweet! Now break it in gently and then do a major burnout! :cool1:
  11. LongIslander26
    Jun 25, 2005
    256
    Good deal!
    And there ya go! Now go drive it up to the rockers in a mudhole! :waytogo: :woot:
  12. muscle
    May 28, 2000
    408
    Show Low, AZ
    Hey did you guys know a V8 is better than a V7? :D
    anyways here is a pic of the motor i posted on a previous post a while back. I just took her around the block (dirt roads few houses) and she is very peppy and responsive. sounds good without the hood and open headers. but im takin her easy then we will open her up a bit. :wink1:
