:help: 89 Chev Subrurban Won't Start "Update"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eatsjeeps, Dec 8, 2002.
  1. eatsjeeps
    eatsjeeps Registered Member
    Dec 7, 2002
    23
    Portland Oregon
    :help: 89 Chev Subrurban Won\'t Start \"Update\"
    Well tested all carb Items I could test and it tested ok
    Now we have moved on to NO SPARK or INTERMITENT SPARK.
    from coil.
    If I crank it long enough or often enough I get spark occasionally. But never long enough to start the rig.
    I guess that would explain why I could get it started before by stuffing a screwdriver in carb it wasnot that that was helping but was buying time, and waiting for intermitent spark. any Ideas
    the coil on the Sub and coil in manual are not the same but we have tested the coil to the best of our ability and it seems to be bad. Get infinite reading on high energy
    and low reading low side /forums/images/graemlins/1zhelp.gif
    I just recently bought an 89 chev /forums/images/graemlins/burb.gif subruban 4x4 to haul
    all six kids and the wife around.
    Any how this is what it seems to be doing.
    On cold starts floods with out touching the gas pedal.
    was able to start after a bit with long screwdriver in
    carb hold throttle open but now that does not work
    either.
    All recent work done:
    just replaced all plugs
    wires
    distributer
    new coil
    new starter
    new battery
    and new ignition switch at bottom of colum not key
    switch
    I don't think any of these things would have affected
    the carb
    Any Help or Ideas would be of great help.
    Marty /forums/images/graemlins/burb.gif /forums/images/graemlins/burb.gif
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    Re: 89 Chev Subrurban Won\'t Start
    well you say you can stick a screw driver in the TB to make it run, well sir you have a TBI motor, i had a similer problem, but it turned out that my idle air control module wasnt working right, so i bought a new one, and it worked well. did the whole high idle thing and stuff, or it could be your temperature sensor in the manifold, that will do it too, the IAC is about 36$ at autozone, and the temp sensor is 12$ at autozone, see if this helps, i hope it does. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Is it a carb or a TBI...makes a big difference in diagnosing the problem...
  4. eatsjeeps
    Dec 7, 2002
    23
    Portland Oregon
    It is TBI sorry
  5. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    yeah if it only does it at idle (it sounds that way) replace the IAC (idle air control mudule) that'll probably do it.
  6. eatsjeeps
    Dec 7, 2002
    23
    Portland Oregon
    Pavement...you'll both sit there looking like a couple of dumb fawks spraying driveline parts at each other and not moving. -rene
    was this directed towards me?
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    No, that is a signature, just about everyone has something different in their sig line, you can do yours in your My Home section.
  8. eatsjeeps
    Dec 7, 2002
    23
    Portland Oregon
    Thanks Tazz
    /forums/images/graemlins/grin.gif
