Help a buddy out. Is his truck toast?
Discussion in 'The Garage' started by Dirty Dave, Sep 19, 2002.
  1. Dirty Dave
    Dirty Dave 1/2 ton status
    Dec 21, 2001
    101
    Kentucky
    A buddy of mine came to me today with a K5 suspension/axle problem. I am clueless about this type of thing so I thought someone here could help.
    He has a 86 K5 and was out the other night and busted his 10blt. He had a local shop swap in a 14blt and 8 lug 44.
    He got the truck back today and while pulling in my driveway he rubbed the front passenger side tire on the fender. I found this strange so I measured from the tread to the bottom of the fender well and got 3in to the back and 4in to the front. The drivers side is the exact opposite.
    Just guessing I say he hit something, but he says he cant recall hiting anything hard enough to do that. Could the shop have messed something up? How bad could this be to fix, if it is fixable?
    All opinions and responses would be appreciated especially since this is his daily driver.
    Thanks in advance.
    Dave
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Did you check and see if the ground was level and the wheels were straight? Its the easiest thing to check
  3. Dirty Dave
    Dec 21, 2001
    101
    Kentucky
    That was the first thing I checked.
  4. dubl_t
    dubl_t 1/2 ton status
    Jun 8, 2002
    141
    Oregon
    didja check th eu-bolts? sometimes they loosen up
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    make sure the ubolts are tight and strait up.
  6. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Check to make sure everything is tight, if it is, the shop may have put a leaf spring in backwards. I've seen dumber things done.
  7. Grim-Reaper
    7,385
    Atlanta
    May have a sheared center pin and the axle is sliding backwards.
    Few things to check.
    Measure from the front spring mounts to the frame mounted piviot point on the shackle. This will tell you if you have a bent fron frame.
    Measure in a X accoss a couple common points on both sides of the frame again to make sure the frame is straight. Measure from the eye down to the center pins. May be drilled wrong.
  8. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    Hey Grim.
    When I accelerate from a stop it feels like the whole body of the rig is sliding back onto the rear axle, or like my rear axle is sliding out from under me -- could it be the sheared center pin your're talking about? Where would I look to check that out? Thanks.
  9. Grim-Reaper
    7,385
    Atlanta
    No I would start checking for cracked leafs and bad body mounts. does that truck have a body lift? Watch the t-case shifter. Left and right from the engine torquig is normal. a little front tro rear is normale. a LOT of front to rear is not. I can tell you right now the cab mounts are shot especialy the ones right at the front of the rear floor. Yours is the same as mine and mine were crushed a good inch. New set did wonders for weird noises and sloppy feel in the body.
  10. 77Jimmy
    Sep 3, 2002
    661
    Atlanta, GA
    Ok, will do. No, no lift on the truck.
    Thanks. /forums/images/icons/grin.gif
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    No lift ???? Well ya better change that. LOL. I'm just giving ya hell.
  12. BIG STEVE
    BIG STEVE Registered Member
    Jul 23, 2002
    66
    thornton colorado
    Common somthing is cockeyed spend some time and look ever
    thing over you just took the easy way out and hoped some one a thousand miles away could point it out if a were next door no problem
    90 jimmy spent years as mechanic and service manager for
    heavy eguitment company we wont abandend you just give it a little effert our tell me to go to hell /forums/images/icons/grin.gif
  13. Dirty Dave
    Dec 21, 2001
    101
    Kentucky
    Thanks for the replies everyone. We will be checking everything out today.
    BIG STEVE I would like to think you in particular. You have confirmed my belief that every group no matter how cool always has at least one [censored].
