HELP!!! A/C install project
Discussion in 'The Garage' started by buffblazer, Jul 1, 2005.
  1. buffblazer
    buffblazer 1/2 ton status
    Jan 5, 2005
    2,395
    Hudson Colorado
    HELP!!! my 86 has no A/C and i plan to install it now my question is, should i go with the orginal parts or get a aftermarket one. also how hard and how long will it take and should i do it myself or have a professional do it?
  2. nmaggie99
    nmaggie99 Registered Member
    Jun 24, 2005
    11
    Anchorage, AK
    Check these posts from earlier..... Your easiest will be aftermarket, Old Air or Vintage Air, but will set you back about $800-$1000... Factory style can probably be done if you have the time, the patience, and fabrication skills to make it work. Good Luck!!!
    http://coloradok5.com/forums/showthread.php?t=142166
  3. buffblazer
    Jan 5, 2005
    2,395
    Hudson Colorado
    thanks for the help
