Help a noobie out
Discussion in 'The Garage' started by CustomChevy, Oct 23, 2005.
  1. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    This is the read diff in my pickup. From lookin it over and comparing with the diff guide here I have to say its a GM 12 bolt. am i right?
    What are my locking options for this diff? I'm waiting on a dry day to crack it open and see what I have for gears ... but I know no matter what I want it locked up.
  2. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    The 12 bolt is the only one with 12 bolts holding the cover on...so I'd have to concur and say that definitely is a GM truck 12 bolt. :D
    The con is that it isn't any stronger than a 10 bolt...:eek1:
    Rene
  3. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Yes it's a 12 bolt. Here's my advice. Don't lock it. Try to find a full floater 14 bolt and lock that. I have broken front and rear axles in 10 bolts locked. A big waste of money and you caught me on the wrong day with this post. I just got back from a short day trip that turned in to a evening trip because of a broken front stub shaft. It seems that even upgrading your axles doesn't help much. Any one know if Yukon Axles have a life time warrenty? I can't find anywhere on the net that states this. Tommorow I will start hunting down a front D60. I'm getting sick of these weak diffs. The FF 14 bolts already sitting in my driveway.
  4. CustomChevy
    Jun 29, 2005
    4,328
    I've thought about the 14bolt ... my problems with that are 1. Space to make the swap 2. The cost of the axel and 3. I really only just run through mud and only want the locked for that extra little UMPH to get out of a deep hole.
    Its not that i'm not into rocks, just around here mud is alot more common.
  5. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    Well, for a little perspective I fragged my old 12 bolt backing out of a parking spot...:doah:
    14 bolts are cheap, although there is certainly more involved than the cost of the 14 itself.
    Rene
  6. Tenpack
    Tenpack Registered Member
    Feb 7, 2005
    16
    Vancouver, B.C.
    A 14bolt FF wouldnt hurt all. From my understanding, there are 3 factors when swapping in a 14 FF.
    1.) Spring perches: most likely need to be re-welded to the proper width
    2.) Drive-shaft: needs to fit the new axle
    3.) Brake lines need to be connect
    A 14b FF here doesnt go for anymore than 300. Search and you can find one with 4.10's.
  7. CustomChevy
    Jun 29, 2005
    4,328
    For reference, this is what my truck looks like (after some good muddin to my opinion)
  8. CustomChevy
    Jun 29, 2005
    4,328
    no welder :\
  9. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    Get a 14 bolt from a 3/4 ton and the perches will line right up...
    Even a SF 14 bolt would be a huge improvement IMO.
    Rene
  10. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    The Hell you say!
    14ff come out of picknpull for 1 dead president, and 50 if you catch them on the manager special weekend.
    time to save your pennies! :rolleyes:
  11. CustomChevy
    Jun 29, 2005
    4,328
    ok guys heres the point. I can't move to the 14 yet (read for a long while), but i do want to lockup that 12bolt. Is there a detroit in existance for that axel? anything other than the govbomb (no need to speed up my axel's apparently impending doom)
  12. CustomChevy
    Jun 29, 2005
    4,328
    oh and go vote! WE'RE LOSING
  13. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
  14. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Just throw in a gov bomb like I have done until I put 14ff in there. It is holding up well for bog. I am going to step out of the bog scene and get into rocks now so I want strength. Once you blow up the bomb, then you will see the light aswell.
  15. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    There is a new post in parts for sale for 14ff ummmm like 125.00.
  16. CustomChevy
    Jun 29, 2005
    4,328
    where can one get a bomb on the cheap??
    and the other question i forgot to ask in the main post, I'm no master mechanic, but do have a passable set of tools. How hard would this be to install. is it just pop out old spider gears and slide in locker?
  17. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    DON'T INSTALL A GOV-BOMB!!!! You pay $259 for the quik-lok and it's done. Buy a gov-bomb, have it blow up, then replace the ring and pinion...that would cost more than just getting the locker. Besides, the gov-bomb you will need to shim and set up the carrier, not easy for some people. The locker you just pull the axle shafts and the spider gears and replace with the locker and you're done.
  18. CustomChevy
    Jun 29, 2005
    4,328
    teh EZlocker (which i assume you mean when you say quikloc) says its rated for upto 33" tires. I am currently running 33's.
    Greated I'm now to anything axel related, but with vehicals in general i try to not ride the top of the recomended list, just doesn't feel right pushin it like that. Unless someone has one in a similar application and can tell me its ok.
  19. Brocky
    May 22, 2005
    1,170
    I would love to see a pic of your Burb by the way. Guys here in Newfoundland try to tell me a K5 is too big for the trails. My answer to this.... I am thinking about buying a 3/4 ton Burb now.
  20. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    Dead President? Would that be Jackson or Grant? :D
