Help all my lights are messed up and i have a safety tomorrow
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chris12, Sep 26, 2006.
  1. chris12
    chris12 1/2 ton status
    Apr 23, 2006
    267
    Forest Ontario, 1/4 hr from Port Huron Michigan
    HELp me everyone. The truck goes for a safety tomorrow and the lights are all messed up here is what i gathered.
    Tap Brake pedal- Radio light flashes
    turn right - all lights a working
    Turn left- radio light flashes, both taillights and licencse plate light flashes,(L) fender light flashes, grill lights flashes(L and R), left fender light wont flash
    Hazards- radio light flashes, taillights flash, grill lights flash (L,R), plate light flashes, (L,R) fender lights dont flashes.
    Lights Full pull - i get a buzzer but if i turn the knob buzzer stops, but then i loose the radio light, rear taillights work, front end ligths all work
    Runners- i get a buzzer but if i turn dial buzzer gowes away but loose radio light, tailights all work. plate light is on, grill lights on and side marker lights on both fenders a on.
    Reverse tailight revers works on both tailights, and no other ligths on, so im ok with the reverse.
    And
    if i press the brake peal i get a buzzer ad if i turn the ligth knob buzzer goes off but loose radio lights.
    OK i hope somone can help me out a si really need the help bad.. This k-5 is booked for safety and e-test tomorrow.
  2. chris12
    Apr 23, 2006
    267
    ttt need some help on the diagnoses here. even if you only know one . then its a start. Does anyone think it could be grounds.
  3. FlagBurb
    FlagBurb Registered Member
    Oct 3, 2002
    58
    Tucson, AZ
    I had some similar problems with my rear turn signals and my stop lamps and reverse lights. I cleaned the grounds for the rear lights and replaced the bulbs - that took care of my issues. Good Luck...
  4. chris12
    Apr 23, 2006
    267
    Im thinking i migth have the bulbs mixed up like the single and the double filiment mixed up im going to go check that and some grounds and see what happens
  5. chris12
    Apr 23, 2006
    267
    Fix. Thanks for the help FlagBurb
  6. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Bad grounds would be my first suspects also.
