Help!!! asap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Orange, Oct 29, 2000.
  1. Orange
    Orange Registered Member
    Apr 2, 2000
    32
    Prescott Valley, Arizona
    I need to know if I have to take off my torque converter along with my tranny. Or can I just leave the converter up bolted on and just change trannies? Which way would it be easier? Any help would be appreciated asap because I need to put my new tranny in tonight. Thanks
    Ok I'm done. OH DAMN!! It broke again.
  2. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    I would imagine it would be best to remove it along with the tranny. Then put it on the new tranny and install it as 1 unit. The reason is because you want to make sure the converter is on all the way. Maybe others who have more expirience with tranny's will be able to give you a better response.
  3. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    most certainly pull it with the tranny. Its only an extra 3 bolts! Save you TONS of headaches. While you have the TC off replace the seal and clean the shaft.
  4. Orange
    Apr 2, 2000
    32
    Ok I tood it off along with the tranny. Now that I think about it, it seems alot more logical to do it that way. I am changing seal between the tranny and the t-case. It was shot anyways. Now I have to find them. Any ideas where to get them at? Thanks for the help
  5. Take them off together and definately have the TC on the tranny when you put it in so you don't mess up the input seal op the tranny.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Be sure to put the torque convertor back on correctly. I got in a rush and didn't install the convertor right and fried the trannies oil pump. I had to do the whole thing over again, Youcan buy the seals at any auto parts store as far as I know.
    creepin' and crawlin'
    Jim
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Hey man, Gimme a call if you need help. Send private, and I'll give you my number.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  8. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I would also either have the converter flushed or replaced while it's apart. Also, replace the rear main on the engine. I didn't do that the first time I did my Burban so I had to pull it back out about year later.[​IMG]
    blazen91
  9. Grim-Reaper
    7,385
    Atlanta
    If the old tranny granaded (burnt up till it misses gears or slips in gear) you really should put in a rebuilt or new converter. If there isn't a drain pulg on the converter there is no way to get the fluid out and your going to end up pumping trash into the new tranny. Even with a drain plug your not going to get all the trash out. Flush the cooler also.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
