Help ASAP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by flynhi, Aug 13, 2003.
  1. flynhi
    flynhi Registered Member
    Jan 29, 2003
    24
    Tracy, CA
    I am forced to drop my turbo 350 trans to change the flywheel ( rounded teeth ) I need to know what tools I need to do this ..... I have to get this done TODAY so any help, recomendations , hints or whatever will be greatly appriciated. I have never done this before....... I feel this project is a desaster waiting to happen
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Haven't done this in a while, but I think it's pretty straight forward once you get the tranny down. I'm sure someone here can give a better answer though. Got a service manual?
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Socket set
    Loooong extensions
    a swivel socket adapter would help
    floor jack to lower the tranny
    a second person to keep you from being crushed to death
    ...that's all I can think of FAST.
  4. flynhi
    Jan 29, 2003
    24
    Tracy, CA
    All I have is a Chiltons repair and tune up guide ( big help ) and limited tools ... but I can borrow some ... just not sure what to borrow ....
  5. flynhi
    Jan 29, 2003
    24
    Tracy, CA
    I have heard of a way i can do this without dropping the trany completely, .... by removing driveshafts unbolt transmission and slide it back, and this should give me 5-7 inches to get a socket yp there and undo the bolts on the flywheel .... is this way doable ?????
  6. flynhi
    Jan 29, 2003
    24
    Tracy, CA
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Conceptually, you can unbolt the front and rear driveshafts (block your tires FIRST!)
    - Unbolt the tranny from engine
    - Unbolt crossmembers from frame
    - Slide the entire transmission/transfercase combo back to get access
    The flywheel nuts may be LocTite'd on there, so it's not clear if you'll have enough leverage to break them free in that position.
    Oh yes, that reminds me you'll want a torque wrench for the reassembly.
  8. flynhi
    Jan 29, 2003
    24
    Tracy, CA
    well here goes nothing ..... I am sure I will be back to ask how to fix what i have messed up /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
  9. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    You should also replace your starter drive gear, doesn't make much sense replacing the flexplate and not the starter gear. You will end up with the same condition and from what it sounds like your not looking forward to doing it this time, take my advice also see how your starter engages the flexplate, you might have to shim the starter to get the proper alignment.
