Help, bad sound from transfer case (?)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mastiff, Aug 3, 2003.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Just noticed this. When I'm in 4-Low and I go from reverse to park, it makes a terrible sound. It's like a high pitched sound of gear teeth rubbing against each other. It's just for a fraction of a second and then it stops (catches)? It sounds like this: Bzzzt. /forums/images/graemlins/grin.gif
    It doesn't do it from 4-High, only Low. And another wierd thing is that it seems to take two cycles to do it: I hold my foot on the brake and go P-R-P-R-P, then the noise. Like the first time from R to P doesn't make the noise.
    I have no idea if it's in the T-case, or maybe the front axle. I've got the stock front 10-bolt with an Auburn. Everything seems to be working right, it's just a nasty little noise! /forums/images/graemlins/frown.gif
    Thanks for any ideas!
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    you should really stop moving before throwing it into park...or maybe pull it out of 4lo before putting it in park..does it sound like this :
    DumbassDumbassDumbass.Dumbass..Dumbass...Dumbass....Dumbass.....clunk"
    [/ QUOTE ] -Twiz
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
  3. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I'm not sure if you're giving me hell or if you're serious. This is sitting still the whole time, foot on the brake.
  4. Confedneck
    Nov 1, 2002
    5,236
    a little of both, and bringing up an old post lol..i dont see why youd put it in park with it in lo range though, i dont think you're supposed too..im not sure that the parking pawl could handle the torque multiplication
  5. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Never heard of this before. I've always put it in park before if I'm out romping around in 4-Low and want to stop for a sec.
    I don't think I fully understand what happens when you shift into park. I always figured it was the same as neutral except that something engaged to prevent the output from turning. Is there something more to it?
  6. Confedneck
    Nov 1, 2002
    5,236
    now you're asking one of the non tranny expert guys lol...hopefully someone else can shed some light on the whole parking gear setup...but if its just now starting to make the noise...there's probably something wrong or starting to go wrong...
  7. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Nobody has any idea what this might be? /forums/images/graemlins/confused.gif
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i know there is a sprag, with a spring, that falls into place when in park, but when the output or internals are spinning then the sprag does not engage and buzzes under the spring's pressure when trying to fall into place.
