HELP... Blazer making a grinding sound
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kwcdawgfan, Apr 18, 2001.
  1. kwcdawgfan
    kwcdawgfan Registered Member
    Jan 13, 2001
    91
    Georgia
    under the front... Talked to a couple of ck5 guys in the chat room earlier and they said it may be the spider gears... Will make the sound when you are driving straight and will last for a couple of seconds then go away... Ive got a 73 k5, automatic with fulltime 4x4... Any thoughts appreciated...
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Had a similar prob. on my '77K10 with fulltime. It was the spindle bearing. This is the small needle bearing that the sub axle rides on. It is located just inside of the outer seal on the inboard side of the steering knuckle assembly. Some of my terms aren't right, but I hope you get the idea.
  3. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    i had something that sound like that what my problem was the the axle was splines where wore off (it was werid)
    AJ
    (Your right i dont understand the jeep thing)
