help bleading lines
Discussion in 'The Garage' started by ramjet gmc, Jul 20, 2003.
  1. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    Well I have installed the Dana 60 and 14 bolt with the disk brakes and the pedal is so soft. I do not think the back is even at 5% I have read that some of you are getting good results with power bleeding is this the tool you are talking a bought
    just some in fo
    dana 60
    stock por valve 1986
    stock 1/2 ton pbb 1986
    good new lines( no ruber hose) SS flex
    Kit allows one person to bleed brake fluid easily/cleanly.
    Vacuum pump alone can test vacuum operated sensors/components. Specially designed adapters fit all brakes.
    · Vacuum pump, brake fluid jar, large/small tapered/suction cup/universal adapters ·
    Tee fitting, cushioned handle grips, 1/4 and 1/8 in. hose adapters, valve adapters ·
    Sealant lubricant to prevent brake fluid bubbles, 24 in. vacuum hose, 24 in. bleeder hose ·
    12 in. hose, owners manual with detailed instructions ·
    Check: distributor advance, PCV valve, EGR valve, heater/AC baffles ·
    Check: headlight cover doors, vacuum switches, valves & diaphragms, transmission modulator · Vacuum pump has durable, solid brass cylinder, cylinder head and piston
  2. Grim-Reaper
    7,385
    Atlanta
    That's what I use but I use the Cheap Mity vac I got from either Auto Zone or Pepboys.
    You probably have Air in the Combination valve. With a full resivior crak open the lines coming form the master. Tap it while it's draining. That should get the air out of the CV.
  3. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    i ran into the same problem when i did mine but i also converted to hydroboost. i have the phoniex injecter. that looks somewhat the same, made bleeding the brakes so easy.the phoniex injects the brake fluid at the caliper and forces the air out at the m/c. it only took about 35 minutes to do the whole system. good luck /forums/images/graemlins/thumb.gif
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    84...can ya post a link to that phoenix injector...that is the best way to bleed brakes because air is lighter than the fluid and naturally wants to go back UP into the system...
  5. ramjet gmc
    Dec 19, 2001
    3,370
